6AS7GA as push pull output?
Old 8th November 2018, 02:30 AM   #201
mr2racer is offline mr2racer  United States
mr2racer's Avatar
I really like that layout. LTP feeding a second stage.
Artificial intelligence is no match for natural stupidity- Red Green
Old 9th November 2018, 04:35 AM   #202
rongon is offline rongon  United States
rongon's Avatar
How does that design get away with its push-pull driver stage using an E88CC (6922, or industrial 6DJ8) with +190V plate-cathode? I know the current is low, so the E88CC is only running at about 600mW dissipation, but still, that's a lot higher than the rated max plate voltage.
Maybe something like a 6CG7 would be better there?
Old 9th November 2018, 12:15 PM   #203
Lingwendil is online now Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
6CG7/6SN7 would do well too, and then you've got the front end from the 6L6GC AB2 basically. Gain will of course be less, however.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 12th November 2018, 03:27 AM   #204
mr2racer's Avatar
Unless I'm mistaken 6CG7 is just a noval version of 6SN7.
Old 12th November 2018, 04:17 AM   #205
Lingwendil's Avatar
It is. Just derate the heat since the bottle is smaller, otherwise they are electrically the same, although some 6CG7 (and 6FQ7) should have a shield between the two nodes, tied to pin 9.
Super handy tubes, I grab them every time I find them cheap.
Old 12th November 2018, 04:52 AM   #206
kodabmx is offline kodabmx  Canada
I bought a bunch of them, but now I find myself using 6N3P instead...
Old 12th November 2018, 10:11 PM   #207
richardr is offline richardr  United States
Originally Posted by Shoog View Post
Built a few but abandoned the valve in the end because they had self resonance issues which was very noticeable with my 100db/w speakers. Produced a high pitched wine which would come and go at random. Others have reported similar experiences in headphone amps using these valves.
Shoog
My experience as well. The 6AS7G is just a very noisy tube. The 5998A is better but, impossible find in NOS condition, instead they are thrashed usually.
Old 16th November 2018, 02:47 AM   #208
mr2racer's Avatar
Can IXCP10M45S be used as a constant current sink for the LTP and second stage?
Old 16th November 2018, 07:16 AM   #209
artosalo is offline artosalo  Finland
artosalo's Avatar
Yes. Look the application at the end of this web page:
Tube DIY Asylum
Old 16th November 2018, 06:42 PM   #210
stocktrader200 is offline stocktrader200  Canada
if you are going to use silicon, a 400v NPN power transistor hung off 6922 will produce 30 watts p-p from a 150v B+ and 3k transformer.
6AS7GA as push pull output?Hide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
Push-pull output impedance SpreadSpectrum Tubes / Valves 6 7th March 2008 12:38 AM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 10:48 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Push Pull Output Stage Question 316a Tubes / Valves 4 10th February 2003 02:04 AM
