Audio Note M10 Clone
Why would you expect the same result?! Please compare the two circuits you posted above, do you not see the differences in the grid voltages? Another case of garbage in garbage out...
what fool I am, I thought the DC of grid will not affect the tube:boggled:
after add a 130V DC to the grid, it is same as the real circuit. Thank you very much:D
Now put all to the circuit, It works.
Output wave is not good
Output wave clearly shows clipping.
Did you simulate the voltage gain of this stage? It will be more than 50. :eek:
Do you expect this to be a normal line stage? :confused:
In the complete M10 preamp it is attached to a low gain phono stage (gain approx. 40, delivering some 200 mV into your line stage with a standard 5 mV input); that's why you need the "excessive" gain of your stage.
But this has been mentioned before, remember? :rolleyes:
5687 operating point is poorly chosen; try 7k5 of cathode resistance.
