6J1 China preamp thoughts
Old 5th June 2019, 02:26 PM   #151
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
I tried to add the resistance into the heater circuit by changing out the R1 (2.2 ohm) with first a 39 then 33 ohm, 5 watt but it seems the current isn't dividing as nicely as I'd hoped.
With the 39 ohm, I did not get the V2 heater to operate.
With 33 ohm, I got V1 looking normal and a faint glow out of V2.
So I think I'm going to need to drop in a regulator (got some buck converters on the way).
Do I still need to have a higher value at R1 then R1->regulator->V2;
or revert to the 2.2 ohm;
or remove R1 altogether?
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 23rd June 2019, 04:21 AM   #152
nymeria96 is offline nymeria96
Hey guys. I pretty much got the FX Audio Tube 01 preamp. Added the GE JANs and it sounds nice. Is there any mods that I can do to further enhance the sound? Maybe PSU, or changing something on the PCB? I am quite handy with soldering.
Old 15th September 2019, 07:32 PM   #154
Soundengine is offline Soundengine
Just finished to build the kit, fun project and nice sound but 2.2 ohm 2 watts is getting very hot like I cannot let my finger on it...Is it normal or it's pooly designed ? I would like to use this preamp safely.
Old 17th September 2019, 12:12 AM   #155
avtech23's Avatar
That resistor is dropping around 1.8W in my build so I changed it out to a 3W resistor to increase the longevity and decrease the temperature load.
It was running a little too close to limit for my liking.
If you are uncomfortable with how hot it gets, try increasing the power rating of the resistor to 3 or 5W.
6J1 China preamp thoughtsHide this!Advertise here!
Akita 12V preamp thoughts prezden Tubes / Valves 13 23rd August 2013 02:00 PM
lf412 for phono preamp- thoughts? rcollege Analogue Source 5 14th November 2011 07:12 PM
lme49710 preamp from china richardAUT Analog Line Level 6 27th October 2011 03:59 PM
China preamp Xiang Sheng 768A piero7 Tubes / Valves 2 4th November 2010 07:57 PM
thoughts about a 'universal' preamp ErikdeBest Tubes / Valves 16 30th March 2010 08:56 PM
Copyright ©1999-2019 diyAudio
