Any guesses on this tube
Old 22nd May 2017, 11:42 PM   #1
rsumperl is offline rsumperl  United States
rsumperl's Avatar
Default Any guesses on this tube
Good evening everyone,
Well, yet another impulse buy, got these for $10 for the pair on that most famous auction site. My first thought is they are 8236s, but hey I don't know. Do the numbers on the base tell us anything???
Ray
A great pleasure in life is doing what people say can't be done.
Old 23rd May 2017, 12:33 AM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
6146.
If there are no dogs in Heaven, I don't want to go there.
Old 23rd May 2017, 01:11 AM   #3
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
If you can figure out the pin-out, that would narrow it down considerably. Then measure the heater current at 6.3 V (assuming that lights it up properly).
Old 23rd May 2017, 01:27 AM   #4
TheGimp's Avatar
He asked for a guess, not a logical analysis.
Old 23rd May 2017, 01:38 AM   #5
WE could do a process of elimination...
It's NOT a 12AX7. Your turn....
Old 23rd May 2017, 01:49 AM   #6
Shef is offline Shef
Shef's Avatar
Hm... not a KT-88 either... next one?
Old 23rd May 2017, 01:58 AM   #7
TheGimp's Avatar
Not a 6P41S either.
One of those weird triodes with the grid on top?
Old 23rd May 2017, 02:05 AM   #8
We are left with the hammer option. Or destructive testing. (where's Tubelab)
Triode or Pentode?
How many Watts will it take before bursting into flames?
Time to call in the experts:
Old 23rd May 2017, 02:15 AM   #9
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
it is octal so 7403, or 3d21wb
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd May 2017, 02:29 AM   #10
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I have been known to "test" mystery tubes.....usually not destructively. I prefer the term "boundary testing." I find the glow point and back up a bit. Before any testing can be done, the pinout must be determined. The plate is obvious, and the heater should be fairly easy to figure out. The rest should be possible with careful examination.
7403 has an odd pinout, but an easy test. Heater is on pins 1 and 2. Tung Sol did make them, and the square plate looks about right.
The OP had previously stated that he had some 7403's, so some comparisons should be in order.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Any guesses on this tubeHide this!Advertise here!
Tube vs. Jfet Preamp for Dynaco ST-35 tube power amp rcollege Tubes / Valves 16 25th November 2013 10:56 PM
FS: Yaqin CD-1 Tube Buffer w/Mullard 6DJ8 Tube. Adds tube warmth to any system. matevana Swap Meet 2 15th June 2013 12:35 PM
My Fender Twin Amp Not Working - get your guesses in MrBigAxe Instruments and Amps 19 8th November 2010 07:11 AM
Any guesses on the age of these skooter Car Audio 32 21st September 2008 01:08 AM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
