This is a grounded cathode amplifier. By the looks of it it will give a signal gain of 10-14.
A buffer is made from a cathode follower 99 percent of the time.
By adding a cap to the input (22nf), rb = 1k, rk = 47k taking the output from out2 through a 1uf cap you will turn the circuit into a less than unity buffer. I would also lower the grid stopper from 22k to about 300R.
It's rather hard to see what the circuit was actually designed for with only moderate gain and fairly high output resistance.
It looks like the front end of a power amplifier, the output would feed a phase splitter?
But it's already push-pull
It's two single ended grounded cathode amps in the same drawing, nothing push pull about it.
Buffers should have gain=1 (or thereabouts), high input impedance and low output impedance. This circuit has just one of those properties, therefore it is not a buffer.
It looks more like one of those circuits you find on a general circuit website, with a description something like "here is a useful/universal amplifier". It is useful in the sense that it has some gain; it is universal in the sense that it would be equally unsuitable for most amplification purposes.
- Tubes / Valves
- Why is this a buffer?
