More Ruminations on Screen Drive/Crazy Drive
Old 30th August 2018, 05:54 PM   #201
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Crazy drive uses HV direct screen V drive, with a resistor from g2 to g1 (call that Rg2g1) and another resistor from grid1 to cathode (call that Rg1k).
The main drive is then via HV grid2 voltage drive, with grid1 acting as a current driven drive at low plate current, which compensates for gm2 being low at low plate current. The grid1 current drive saturates as plate current increases due to Rg2g1 and grid1 current dragging on it, while gm2 picks up with increased plate current and Vg2. The net effect is to get constant -total- gm drive of the tube. The resistor Rg2g1 is selected to get this compensation correct. Rg1k just acts as a pull down to help turn the tube off, but also affects the compensation some.
a) 26LX6 normal grid1 drive
b) 26LX6 grid2 only V drive
c) 26LX6 Crazy/Twin drive
d) 12HL7 Crazy/Twin drive
e) 40KG6 normal grid1 drive
f) 40KG6 grid2 only V drive
g) 40KG6 Crazy/Twin drive
File Type: jpg rsz_40kg6_twin_3p5vst_888rg2g1_2770rg1k_50_50.jpg (74.9 KB, 9 views)
Old 17th October 2018, 08:15 PM   #202
DIYBras is offline DIYBras  Brazil
DIYBras's Avatar
18GV8Single2W+2W
Not exactly Crazy Drive, due to CCS making the divider ratio 1:1 for G2/G1, relying only on G1 current (if any) to make the division. Interesting different project nonetheless, albeit with high global NFB.
A lot of projects at same time, all delayed and changing priority every day...
Old 17th October 2018, 08:21 PM   #203
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Unfortunately my Japanese crystal ball is being serviced at the moment. What does this CCS in the pentode's plate circuit do?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 17th October 2018, 08:30 PM   #204
DIYBras's Avatar
My crystal ball showed a message:
Since the diff input (2SJ109) forces the anode voltage to zero (input is ground referenced), I believe that the designer don't trusted to rely only on output trafo DCR for stabilizing the anode current. Is one of these complicated "exercise" projects...
More Ruminations on Screen Drive/Crazy DriveHide this!Advertise here!
6L6 Without Screen Drive? mr2racer Tubes / Valves 36 24th January 2016 11:21 PM
Screen drive and the 6AG9 ultrafi Tubes / Valves 4 22nd December 2015 05:35 AM
Screen drive and other P-P experiments Tubelab_com Tubes / Valves 23 6th July 2010 07:08 PM
UltraLinear Screen Drive TheGimp Tubes / Valves 5 21st August 2009 03:48 AM
drive gone crazy hiwiho Digital Source 19 2nd October 2007 01:29 PM
