Assembling the tube amplifier 6Ж4 - 6П3С.
Old 8th March 2017, 08:06 AM   #1
Vyatcytslav Evgrafov is offline Vyatcytslav Evgrafov  Russian Federation
Default Assembling the tube amplifier 6Ж4 - 6П3С.
Good afternoon! I made this tube amplifier for two years. Lamps 6Ж4 and 6П3С. In North America, these lamps are called 6AC7 and 6L6.
Here is a video https://youtu.be/gU2BZvZSuxo
Here is the scheme
Here is a photo:
Output transformers Hammond 1650PA
OPT1
OPT2
OPT3
ROHM Semiconductor Schottky Barrier Diode
Rohm
Resistors С2-29В
Resistors
Electrolytic capacitors
Ecaps
Polypropylene Capacitors
ICEL MPW
PCaps1
PCaps2
EPCOS B32776
Epcos
Budget.
Since, in High End Audio, the conversation about money is considered nonsense and inappropriate, while I postponed this topic.
Construction
Chassis1
Chassis2
Chassis3
Chassis4
P.S.
Development of a tube amplifier 6Ж4 - 6П3С
The first variant of the construction
Here is a video Video1
Here is a photo Album1
The last version of the construction
Here is a video http://www.diyaudio.ru/forum/go.php?...be/o4QMBtrBwd4
Here is a photo Album2
Old 8th March 2017, 12:03 PM   #2
Eli Duttman is offline Eli Duttman  United States
OK, 3 6AC7s for small signal and PP 6L6 finals. Do you have some measurements?
Obviously, a lot of work has gone into the project. Карашо!
Eli D.
Old 8th March 2017, 01:30 PM   #3
Here the results of measurements made on the stand:
In the final assembly, measurements are not made. If you lean your ear against the acoustic systems, there is no noise. Tried variants of heating by an alternating current and a constant current of a difference is not present.
Old 9th March 2017, 02:55 AM   #4
kevinkr's Avatar
Would you mind terribly using our server to host pictures and test results? Most of the links do not render correctly due to character sets for Cyrillic not being installed in the browser and the links will eventually break making the thread useless to future readers.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th March 2017, 01:28 PM   #5
Thanks see this link https://drive.google.com/drive/folde...1E?usp=sharing
Old 27th August 2019, 03:51 AM   #6
Jikkelstikkel is offline Jikkelstikkel
I see no-one replied to you since 2017. Anyway..thanks for re-posting pics.
And, WOW, you project looks impressive. Well done!
I guess it sounds great.
Assembling the tube amplifier 6Ж4 - 6П3С.Hide this!Advertise here!
Russian 6J43P-E(6Ж43ПE) Dual anode pentode.... Junm Tubes / Valves 9 18th November 2016 03:23 AM
6SJ7 Vs 6Ж8 - Can the russian tube be considered an equivalent tube ? Kagliostro Tubes / Valves 16 16th August 2016 10:00 PM
6П3С-Е Russian NOS: Gas Problem Rod Coleman Tubes / Valves 27 8th December 2013 02:27 AM
6П3С Plate Voltage N4BBQ Tubes / Valves 2 6th March 2013 01:11 PM
2Ж27Л - 4Ж1Л - 12Ж1Л - 4П1Л - How to use ?? Kagliostro Instruments and Amps 9 13th June 2012 06:37 PM
Copyright ©1999-2019 diyAudio
