Let's talk 12BH7
Let's talk 12BH7
Old 8th February 2017, 12:12 PM   #1
mashaffer is offline mashaffer  United States
Default Let's talk 12BH7
12BH7 is an interesting tube. It looks like it might be outstanding in LTP or Cascode service. I have one used one to play with I think so it begs a few questions (in no particular order).
1. Are they prone to microphonics?
2. Are the new production any good?
3. In a cascode using a 12BH7 and a 12AU7 would I get most of the linearity and gm advantage by using the BH in the bottom position?
4. Would you agree that the BH is well suited to these two applications?
Mike
If you are not a part of the Solution... you are a part of the Precipitate
Old 8th February 2017, 12:32 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The 12BH7 double triode is pin compatible with the ECC81, ECC82 and ECC83 series from Mullard but has slightly different characteristics. Brimar give the intended use as TV frame oscillator and frame output. The construction is compatible with audio through to low VHF use.
The thin glass tube envelope is 19 mm in diameter and, excluding the B9A base pins, is 68 mm tall.
Type 12BH7 was first introduced in 1950.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 8th February 2017, 12:33 PM   #3
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Hi Mike,
in Cascode services I'd prefer to use tubes that were dedicated for that, e.g. 6922, 6DJ8 or the European ECC84 (I don't know if there exists an US equivalent). In LTP's a high double triode is favourable over a low or medium one.
As 12BH7 is about in the region of 6SN7/6CG7/6FQ7, you certainly could draw the most out of it if you'd use it like them.
Best regards!
Old 8th February 2017, 11:32 PM   #4
Thanks for the input. The reason I was thinking of the BH7 for LTP is that it doesn't seem to mind operating with a relatively low plate to cathode voltage leaving more for the tail if using a passive tail.
Old 9th February 2017, 02:01 AM   #5
Sodacose is offline Sodacose  United States
Sodacose's Avatar
I recently finished a SET with 12BH7 as the input (choke loaded). I think it sounds very nice. The first 12BH7 I tried was microphonic but that could have been just bad luck.
You're definitely right about perveance. That and a 5687 seem to stay fairly happy at lower anode voltages.
Old 9th February 2017, 08:49 AM   #6
legendre is offline legendre  United States
legendre's Avatar
Originally Posted by Kay Pirinha View Post
Hi Mike,
The 12AT7 / ECC81 is also excellent for cascode service.. particularly in a differential circuit with a CCS.
Old 9th February 2017, 04:36 PM   #7
I've tried a PI circuitry, based on the Stax SRX, You see, it is Van Scoyoc-like design with two 12AT7 in Cascode. Never managed to get it workung sufficiently, due to a great lack of response in the higher audio range.
Best regards!
Old 9th February 2017, 05:12 PM   #8
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Best regards!
Cascode circuits have a very high output impedance, like +2 times the rp of the lower triode. I found an easy solution for this trouble: Neutralizing An Amplifier
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 9th February 2017, 05:31 PM   #9
skidave is offline skidave  United States
skidave's Avatar
The 12BH7 pulls a bit more heater current than the 12A__ series. Just be aware of that if you try tube rolling.
Sent from my SM-J320V using Tapatalk
Old 9th February 2017, 06:06 PM   #10
Thanks, Osvaldo!
Sadly I've forgotten to link to the circuit. I didn't find any schematics in your thread, so where in the 'Stax' circuitry from Buonavolta's pages should I place those trimmers?
Best regards!
Let's talk 12BH7Hide this!Advertise here!
12BH7 Headphone Amp BJosephs Tubes / Valves 69 11th August 2014 09:59 AM
12AU7 vs 12BH7 vs 6CG7 SHiFTY Tubes / Valves 42 17th November 2011 04:05 PM
12BH7 and the Simple SE? Davec113 Tubelab 11 2nd December 2010 02:48 PM
12BH7 Specs sauuuuuce Tubes / Valves 2 16th September 2004 01:22 AM
12BH7 is microphonic Burnedfingers Tubes / Valves 7 1st May 2003 11:35 PM
Copyright ©1999-2019 diyAudio
