Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#401 | |
#402 |
I have also such kind of scope, old, but do well, electronics stay fine plastic case do fall apart.
#403 |
I always add a bleeder resistor with an LED in series so I can see if the amp is still charged.
I remember my first valve pre amp build. I built it up and it didn't work so I turned it off and touched the circuit and got a huge shock. My tutor said I had to discharge the smoothing cap. So next time I shorted out smoothing cap with a resistor. I touch circuit and got a huge shock again, I had forgot to turn it off ! Amazingly, I am now 63 but much more careful.
2020 versions of PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk |
#404 |
That is quite smart, now I am convinced that where is hair, there is al lot less intelligence.
#405 |
For me, I do class d and hybrid amps, I am busy now with smps design, these are really dangerous, so your idea of a led, I do put it in, even in the total pcb for the smps, do I see a red light, I do not touch.
#406 |
Some of my early SMPS designs were a bit touchy and I occasionally had exploding mosfets flying around the room. I used to turn it on from behind a chair to shield me from flying mosfets. What I did in the end was an overcurrent detect circuit on the mosfets.
I used a PIC micro to do the LLC frequencies and this had an input pin for over current detect. I also had an LED output to show if there was an overload. If the PIC detected overload it immediately turned everything off.
#407 |
We have a lot of smps controllers, and when do it right and use a isolation transfrormer things go right, deadtimes are the most underestimated errors.
slowly set voltage up helps, use of a pic is is not suitable for everywhone, need to program. I have some parts, fase shift controllers and resonant, and is a NC1365. regards. |
#408 |
I was a PIC consultant for 13 years so have used them extensively. The program is pretty simple. It just looks at feedback signal. If the feedback is low it decreases LLC frequency. If the feedback is high it increases LLC frequency. If it sees a over load it turns off IR2113 and puts on over load LED. Must be less than 200 lines.
Code:
#include p16f506.inc LIST R=DEC ; LIST ;----- CONFIG Options -------------------------------------------------- ;_OSC_LP EQU H'0FF8' ; LP oscillator and 18 ms DRT ;_LP_OSC EQU H'0FF8' ; LP oscillator and 18 ms DRT ;_OSC_XT EQU H'0FF9' ; XT oscillator and 18 ms DRT ;_XT_OSC EQU H'0FF9' ; XT oscillator and 18 ms DRT ;_OSC_HS EQU H'0FFA' ; HS oscillator and 18 ms DRT ;_HS_OSC EQU H'0FFA' ; HS oscillator and 18 ms DRT ;_OSC_EC EQU H'0FFB' ; EC Osc With RB4 and 1.125 ms DRT ;_EC_OSC EQU H'0FFB' ; EC Osc With RB4 and 1.125 ms DRT ;_OSC_IntRC_RB4EN EQU H'0FFC' ; INTRC With RB4 and 1.125 ms DRT ;_IntRC_OSC_RB4EN EQU H'0FFC' ; INTRC With RB4 and 1.125 ms DRT ;_OSC_IntRC_CLKOUTEN EQU H'0FFD' ; INTRC With CLKOUT and 1.125 ms DRT ;_IntRC_OSC_CLKOUTEN EQU H'0FFD' ; INTRC With CLKOUT and 1.125 ms DRT ;_OSC_ExtRC_RB4EN EQU H'0FFE' ; EXTRC With RB4 and 1.125 ms DRT ;_ExtRC_OSC_RB4EN EQU H'0FFE' ; EXTRC With RB4 and 1.125 ms DRT ;_OSC_ExtRC_CLKOUTEN EQU H'0FFF' ; EXTRC With CLKOUT and 1.125 ms DRT ;_ExtRC_OSC_CLKOUTEN EQU H'0FFF' ; EXTRC With CLKOUT and 1.125 ms DRT ;_WDT_OFF EQU H'0FF7' ; WDT disabled ;_WDT_ON EQU H'0FFF' ; WDT enabled ;_CP_ON EQU H'0FEF' ; Code protection on ;_CP_OFF EQU H'0FFF' ; Code protection off ;_MCLRE_OFF EQU H'0FDF' ; RB3/MCLR pin functions as RB3, MCLR tied internally to VDD ;_MCLRE_ON EQU H'0FFF' ; RB3/MCLR pin functions as MCLR ;_IOSCFS_OFF EQU H'0FBF' ; 4 MHz INTOSC Speed ;_IOSCFS_ON EQU H'0FFF' ; 8 MHz INTOSC Speed ;20MHZ __CONFIG _MCLRE_OFF & _WDT_ON & _CP_OFF & _OSC_HS ;***************************************** ;SUBWF FLAGS ;IF W > MEM THEN NC ;IF W = MEM THEN C ;IF W < MEM THEN C ;IF W<= MEM THEN C ;IF MEM>=W THEN C ;IF MEM<W THEN NC ;***************************************** #DEFINE SET0 1 #DEFINE SET1 2 #DEFINE SET2 4 #DEFINE SET3 8 #DEFINE SET4 16 #DEFINE SET5 32 #DEFINE SET6 64 #DEFINE SET7 128 #DEFINE LED PORTB,0 #DEFINE OPTOINPUT PORTB,1 #DEFINE NOTOVERCURRENT PORTB,2 ;PORTC = GATES FIRSTRAM EQU 0XD ;16F506 RAM START ADDRESS ;10H TO 1FH IN BANK 0 CBLOCK FIRSTRAM TEMP TEMP1 TEMP2 TEMPL TEMPM PULSES ENDC ORG 0 INCLUDE MACRO.ASM CLRWDT CLRF FSR ;BANK 0 RAM MOVWF OSCCAL ;SET UP OSC FREQ ACCURATELY MOVLW 0X30 ;A2D ALL OFF MOVWF ADCON0 CLRF PORTC ;ALL MOSFETS OFF MOVLW 0 TRIS PORTC CLRF PORTB ;LED OFF MOVLW SET1+SET2 ; OPTO AND NOTOVERCURRENT ARE INPUTS TRIS PORTB MOVLW 0X41 ;COMPARATORS OFF MOVWF CM1CON0 MOVWF CM2CON0 CLRF VRCON MOVLW 0XC0 ;DISABLE WEAK PULL UPS ON PORTB OPTION ;WAIT 4 SECS TO LET POWER SUPPLY CAPS CHARGE UP MOVLW 4 CALL WAITWSECONDS ;********** ;SOFT START ;********** RESTART MOVLW 0 MOVWF TEMPL MOVLW 20 ;20ms MOVWF TEMPM SOFTSTART ;166KHz 30 cycle loop MOVLW 1 CLRF PORTC ;DEADTIME NOP ;DEADTIME MOVWF PORTC ;HAVE TO IGNORE OVER CURRENT HERE as s/c to start with CLRWDT NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP MOVLW 2 CLRF PORTC ;DEADTIME NOP ;DEADTIME MOVWF PORTC ;;;;;;;; NOP NOP NOP NOP NOP NOP NOP NOP DECFSZ TEMPL,F GOTO SOFTSTART DECFSZ TEMPM,F GOTO SOFTSTART ;************************************************* ;based on 30uh leakage inductance Lr, Lm =155uH and 200nf Cr ;************************************************* ON BSF LED ;POWERED UP OK MLOOP BTFSC OPTOINPUT GOTO SLOWCLOCK ;GO IF OPTO HIGH (VOLTS TOO LOW) ;;;;;;;;;;;;;;;;;;;;;;;;;; ;FASTCLOCK ; 166KHZ 2 * 15 CYCLE LOOP FASTCLOCK CLRF PORTC ;DEADTIME MOVLW 1 ;DEADTIME MOVWF PORTC ;;;;;;;;;;;; CLRWDT ;LET SETTLE 800ns NOP NOP NOP BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN CLRF PORTC ;DEADTIME MOVLW 2 ;DEADTIME MOVWF PORTC ;;;;;;;;;;;; NOP NOP NOP NOP NOP NOP NOP NOP GOTO MLOOP ;************************* ;125KHZ 2* 20 CYCLE LOOP SLOWCLOCK CLRF PORTC ;DEADTIME MOVLW 1 ;DEADTIME MOVWF PORTC ;;;;;;;;;;;; CLRWDT ;LET SETTLE 800nS NOP NOP NOP BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN BTFSS NOTOVERCURRENT ;GO IF OVER CURRENT GOTO BROKEN NOP CLRF PORTC ;DEADTIME MOVLW 2 ;DEADTIME MOVWF PORTC ;;;;;;;;;;;; NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP GOTO MLOOP ;************************ ;SLOW FLASH LED BROKEN CLRF PORTC ;MOSFETS OFF BSF LED CALL WAIT250MS CALL WAIT250MS CALL WAIT250MS CALL WAIT250MS BCF LED CALL WAIT250MS CALL WAIT250MS CALL WAIT250MS CALL WAIT250MS GOTO BROKEN ;****************************************** ;FAST FLASH LED BROKENSOFT CLRF PORTC ;MOSFETS OFF BSF LED CALL WAIT250MS BCF LED CALL WAIT250MS GOTO BROKENSOFT ;****************************************** ;63 max input WAITWSECONDS MOVWF TEMP2 CLRC RLF TEMP2,F ;*2 RLF TEMP2,W ;*4 GOTO SECS WAIT1SECOND MOVLW 4 SECS MOVWF TEMP2 L3 MOVLW 250 ;250MS LOOP MOVWF TEMP1 L2 MOVLW 250 ;1 MS LOOP MOVWF TEMP L1 CLRWDT ;10 CYCLE LOOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP DECFSZ TEMP,F GOTO L1 DECFSZ TEMP1,F GOTO L2 DECFSZ TEMP2,F GOTO L3 RETLW 0 ;************************************ WAIT1MS MOVLW 250 MOVWF TEMP W1M CLRWDT ;20 CYCLE LOOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP DECFSZ TEMP,F GOTO W1M RETLW 0 ;*********************************** WAIT250MS MOVLW 250 MOVWF TEMP2 W2M CALL WAIT1MS DECFSZ TEMP2,F GOTO W2M RETLW 0 ;************************************* WAIT50MS MOVLW 50 MOVWF TEMP2 W2M50 CALL WAIT1MS DECFSZ TEMP2,F GOTO W2M50 RETLW 0 ;*************************************
#409 |
Thanks nigelwright, is program free? I will test it just curious what it does, I have a while ago search a program for a smps mig welder, I did now put in a big transformer, but smps is mucho better, maybe you now a solution, I think even this program because it has feedback is usable, I need then a very stable and clean supply for the pic, otherwise with welding spikes can kill it or disturb program whit desastreus consequenses for the smps itselfs, I have programmers for most of these chips.
Driving the mosfets needs then a couple of transistors in totempole and a driver transformer, because these pic has not enough current and are not designed for that. In principle you do jus emulate a normal chip and have now own control, completely, I do see also other chips who are be used I have somewhere a program for that who do mig for example, on a atmegachip. I do find pic more easy. I have to look at the transformer, because the primairy is quite low in induction, and I need to fill the coilformer, winding these need some experience. As programming concerns, I can not do that, never learning that, and not so easy as I get older, now almost 63. But I did undo hasp dongles in past and even everkey, so the NOP I see in your programs is much used that day ![]() thanks for the info, kees Last edited by kees52; 3rd October 2019 at 10:30 AM. |
#410 |
Is that pcb program from you? I go download the demo and look at it, because eagle is not interesting anymore I do not like that internet thing in it.
regards |
Thread | Thread Starter | Forum | Replies | Last Post |
Workbench safety practices? | Stormrider | Equipment & Tools | 3 | 3rd August 2008 06:08 PM |
Safety with high volts: 101 | rick57 | Tubes / Valves | 34 | 1st April 2005 05:51 PM |
Safety Practices, General and Ultra-High Voltage | DrDeville | Everything Else | 49 | 23rd September 2004 10:31 AM |
New To Site? | Need Help? |
