VTA M-125 mono block kit.
VTA M-125 mono block kit. Please consider donating to help us continue to serve you.
Old 9th January 2017, 09:19 PM   #21
boatheelmusic is offline boatheelmusic  United States
Actually, it's star grounded.
Old 9th January 2017, 09:20 PM   #22
Try running the yellow negative feedback wire right up the chassis to the board instead of along the side.
Old 9th January 2017, 10:11 PM   #23
dahlberg is offline dahlberg  Sweden
dahlberg's Avatar
Well the yellow wire isn't yellow any longer, it's black and it's screened. It
helped a bit but not all the way. It changed position a bit as well during that
change. I have some consern about filament wiring from the transformer to
the output tubes. Also pentode/UL wiring is drawn between the output tubes
instead of along the side of the input pcb. The signal wire is also changed for a
screened one, dual wire, screen connected at the pcb ground (not in the picture).
Some Music I Like:
https://play.spotify.com/user/dahlbe...tm_medium=open
Old 9th January 2017, 10:14 PM   #24
Be very sure all those screens terminate at the star grounding lugs.
Old 9th January 2017, 10:18 PM   #25
Bob01605 is offline Bob01605  United States
Bob01605's Avatar
Send a message via AIM to Bob01605
The second photo shown in post #18 is not the correct photo of the CCS version of the M-125 amp. That photo in post # 18 may still be online. I will track it down and have it removed. The correct photo for the CCS version of the M-125 is shown below. Yes - As Boatheelmusic has mentioned > You are advised to run the yellow wire that goes to the NFB eyelet on the driver board away from the two wires that connect to the input jack. You should run the wire as shown in the photo below.
Bob Latino
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
Old 9th January 2017, 10:45 PM   #26
dahlberg's Avatar
Bob Latino
Thanks Bob. I will try to relocate the feedback wire tomorrow, how about my filament wiring ?
Some Music I Like:
Old 9th January 2017, 10:49 PM   #27
Bob01605's Avatar
The filament wiring looks fine .. well done ..
Bob
Old 9th January 2017, 10:56 PM   #28
dahlberg's Avatar
Bob
Thanks.
Some Music I Like:
Old 9th January 2017, 11:10 PM   #29
BinaryMike is offline BinaryMike  United States
BinaryMike's Avatar
I'm seeing at least three chassis ground connections, two at the cathode resistors and one at the multi-section 'lytic.
Old 10th January 2017, 12:12 AM   #30
dahlberg's Avatar
The pcb is already connected there, why would it be a better idea to connect the
screens with an additional wire to the star ground point ?
Some Music I Like:
VTA M-125 mono block kit.Hide this!Advertise here!
FS: Dynaco VTA M-125 Monoblocks. (8) KT-120 Power Tubes. LOW Hours madisonroberts Swap Meet 8 18th December 2016 09:38 PM
grounding dual mono to mimick a mono block mozarti Chip Amps 5 27th November 2014 10:07 AM
How to Wire Brain Mono Block Kit jawbreak Chip Amps 5 23rd January 2005 09:29 AM
WTB: Power Transformers For BrainGT Mono Block Kit jawbreak Swap Meet 1 2nd January 2005 07:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
