Russian 6J43P-E(6Ж43ПE) Dual anode pentode....
I was presented by my Ukrainian friend of this tube. I had search on the net about this tube and this are my reference. Now my question is, where i can make use of this tubes?
I'm Planning of a signal splitter aside fom tube pre-amp with two anodes tied together. Can they make a good signal splitter in triode or pentode mode?
What other applications they may be, Any help will be much appreciated.
Thanks..
jun
  • 6J43P-E.pdf
Thanks..
jun
If the curves are real, you can make nice SPUD amp (in triode).
Ua=240V, Uk=-4V, Ik=31mA, Pout = 2W, THD=4%, OTR=5K
I would like to see a proper translation of the data sheet, as this is a small tube which I doubt would be capable of 7.5W triode dissipation.
I have attached my trace of the tube in triode mode with a 3W dissipation line.
I even put a tube on the tester (Avo VCM) and it runs VERY hot at 150v and 20mA on a single anode.
