Hour meter used in previous post :
Rectangle LCD Hour meter gauge 924-48-90 volt golf cart forklift 9-80VDC generic
All that is needed is a few mA DC , a diod from filament will do.
so its 2 years from the time the question was raised so can you tell us how are the tubes working in your amp / preamp?So, are you asking because you are thinking of buying some or because you have a problem with them not lasting?
I run eight of the Psvane CV181 TII tubes in my pimped Audio Innovations Second Audios. Ok, not the Shuguang Treasures but they are Chinese. Anyway I listen to them for about 8 hours per day for 5 days a week. They have been in the amps for about 3 months now and today I tested all 8 valves and they gave identical readings to the day they were installed. That's not many hours in the great scheme of things but it's all I can say so far.
So, come back and ask me the same question in a year or two . . . . . .
Oh, and they sound great.
I ran them for a year with that daily use and there were no issues. Then I sold the amps but kept the tubes and used them in some 845 amps, again without problems.
can you please tell me how many hours you have approximately used them?I ran them for a year with that daily use and there were no issues. Then I sold the amps but kept the tubes and used them in some 845 amps, again without problems.
So its been over 3 years so may I know what is the update on the tubes. How are they functioning now. How many hours you might have run it.
Reliable was a machine using up to 2,400 valves which had to keep working.
This was achieved by not switching them off.
The problem of Chinese valves in Chinese amps
with poor quality control and voltages all over the place is separate.
The problem with this statement about the Colossus is that is isnt tempered at all - no reference to how often a valve had to be switched out.
A quick tour of Bletchley Park will qualify that statement....
I.e. valves failed regularly, not due to unreliability per se, but due to sheer numbers.
I MTBF was 1000hrs in just 1% of tubes, then maintenance was an almost continuous exercise
- Tubes / Valves
- Shuguang Treasure CV181-Z Lifespan in hours?
