8mV of noise causing havoc in valve pre amp.
Old 9th August 2016, 12:59 AM   #1
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default 8mV of noise causing havoc in valve pre amp.
I have managed to get the noise down quite a bit in my pre amp.
I am now down to 8mV AC hum in the first stage.
The 8mV becomes 80mV after the next stage which is pretty useless.
I have changed heater supply to DC and that is rock solid.
I have to connect one side of DC heater supply to zero volts to reduce hum.
I had a transformer very close to the first stage so I have removed it and put it on flying leads so it cant affect the circuit.
I thought perhaps it was star grounding issue but I have made sure all ground are star-ed.
I have ordered a couple of different valves that hopefully should be lower noise, a 12au7 and a Ruby low noise 12ax7.
The second stage works fine if I short out its input, there is zero noise on the output.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk
Old 9th August 2016, 01:02 AM   #2
rayma is offline rayma  United States
How about shorting the input, does that affect the hum? Does a tube shield help? Is it 50Hz or 100Hz?
Old 9th August 2016, 01:26 AM   #3
I have the volume control set to zero.
It is 50Hz.
Shorting out the grid stopper alters the shape of the waveform quite a bit.
Without grid-stopper it is reasonable sinusoidal.
With grid stopper it is a very badly shape sine wave.
Its about 100mV peak to peak.
Old 9th August 2016, 01:33 AM   #4
I have the volume control set to zero. It is 50Hz.
With grid stopper it is a very badly shape sine wave. Its about 100mV peak to peak.
Is the USB input disconnected? There must be some kind of ground loop.
Old 9th August 2016, 02:03 AM   #5
The USB pot is turned off.
Its normally connected to a USB DAC but I haven't added that in yet.
Old 9th August 2016, 02:10 AM   #6
I would remove the coupling capacitor after the wiper and see if the noise remains.
If so, it almost has to be a ground loop.
Old 9th August 2016, 02:16 AM   #7
kevinkr's Avatar
How about some pictures of how things are laid out and are you absolutely sure your pre-amp is not oscillating?
How far is your input stage from the rectifiers and transformer.
How have you grounded things and in particular the HV winding center tap?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th August 2016, 02:55 AM   #8
kmaier is offline kmaier  United States
kmaier's Avatar
Shorting the input to the second stage (if done at the pot input) doesn't actually short it... it simply takes the output noise of the first stage and creates a voltage divider via the two 100K resistors meant to mix the two inputs. The output from the voltage divider drives the input to the second stage. If identical noise is induced to both stages, the input (via the voltage divider) to the second stage is basically out of phase and the end result is likely less noise from the second stage. Without seeing a mechanical layout of the circuit, it's difficult to suggest where the problem is.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 9th August 2016, 10:07 AM   #9
DF96 is offline DF96  England
What does the supply rail to the first stage look like? Is this a PSU grounding error?
Old 9th August 2016, 12:44 PM   #10
Charlie123Maldor is offline Charlie123Maldor
I don't have much experience with tube circuits but I would try a 5-20H transformer type choke on the H2 rail making a RCLC filter after the rectifier. They can be bulky and expensive. If that did not work the next thing I would try is running both anodes off the one rail. Meaning that from HT I would further filter and decouple the voltage and supply the input side anode with that. This might reduce the hum a little as it would see more filtering. I might have to change the resistors to get the required voltage though and also use less capacitance.
8mV of noise causing havoc in valve pre amp.Hide this!Advertise here!
What is causing this noise? terranigma Solid State 27 14th October 2015 10:48 PM
LCD brick causing noise over speakers Ramie Solid State 0 17th February 2015 08:43 PM
Fan causing line noise at turn on moray james The Lounge 0 26th January 2015 04:49 PM
Amp causing popping noise? guitarguy12387 Car Audio 7 15th April 2008 02:58 AM
valve pre amp dudemyster Tubes / Valves 4 13th April 2004 05:13 PM
Copyright ©1999-2019 diyAudio
