Counterpoint SA 3000 Transformer
Administrator
Joined 2004
Hi aherb,
Close will work fine. A little lower on the HV supply would be helpful. If you go up with that, your regulator might be pushed over the line and cook.
Yes, post #7 spells everything out except for currents.
So, what did you buy?
-Chris
PT# for toroidal transformer on sa-3000
I need the part number of the toroidal power transformer from plitron. I’d the upgrade noise tested and electrostatic screen if that makes a difference. I talked to plitron directly but he told me he’d need the part number before moving forward. I don’t have the power supply so if anyone knows what that part number is for the sa-3000 it is greatly appreciated
Administrator
Joined 2004
Hi Noice,
Did you actually lose a power transformer in your preamp?
I'm going to suggest strongly that you remain with an E-I transformer as it is a bandwidth limited device (which is very good in this case). It also has a lower inrush current.
I was the authorized warranty shop for Canada until just before they went out of business. I had never seen a burned out transformer on this model. In the years since they went out of business I have worked to redesign the problem areas with Counterpoint equipment. I have redesigns for most of the preamplifiers and the SA-3000 is the next up to have a power supply redesign. I can say that you are really much further ahead with a good E-I transformer. I'm not trying to sell you anything, and given that you're in the 'States, I am not trying to have you bring it in for service either. All I'm trying to do is keep you from making a mistake. Also, the toroid will require a larger box than the one currently installed if it is sized properly.
For what it's worth, most "upgrades" that Altavista, Elliot and others made were not well engineered. A toroid transformer is certainly not an upgrade compared to a good E-I transformer. What is an upgrade would be a new E-I transformer of higher quality. The core might be slightly larger, and you would have to be careful that the dimensions don't make it too large for the external box.
-Chris
