Counterpoint SA 3000 Transformer
Old 18th July 2017, 12:43 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi aherb,
Close will work fine. A little lower on the HV supply would be helpful. If you go up with that, your regulator might be pushed over the line and cook.
Yes, post #7 spells everything out except for currents.
So, what did you buy?
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 8th October 2019, 08:56 PM   #22
Noice is offline Noice
Default PT# for toroidal transformer on sa-3000
I need the part number of the toroidal power transformer from plitron. Id the upgrade noise tested and electrostatic screen if that makes a difference. I talked to plitron directly but he told me hed need the part number before moving forward. I dont have the power supply so if anyone knows what that part number is for the sa-3000 it is greatly appreciated
Old 9th October 2019, 02:30 PM   #23
Steve Morley is offline Steve Morley  Canada
Part number of the original Counterpoint trannie? See picture in post #17.
S.
Old 9th October 2019, 02:49 PM   #24
Have you seen this:
Obtaining transformers for counterpoint gear
Don't know if it's still current with Pliton info. Scroll down the page to SA3000.
S.
Old 9th October 2019, 04:01 PM   #25
anatech's Avatar
Hi Noice,
Did you actually lose a power transformer in your preamp?
I'm going to suggest strongly that you remain with an E-I transformer as it is a bandwidth limited device (which is very good in this case). It also has a lower inrush current.
I was the authorized warranty shop for Canada until just before they went out of business. I had never seen a burned out transformer on this model. In the years since they went out of business I have worked to redesign the problem areas with Counterpoint equipment. I have redesigns for most of the preamplifiers and the SA-3000 is the next up to have a power supply redesign. I can say that you are really much further ahead with a good E-I transformer. I'm not trying to sell you anything, and given that you're in the 'States, I am not trying to have you bring it in for service either. All I'm trying to do is keep you from making a mistake. Also, the toroid will require a larger box than the one currently installed if it is sized properly.
For what it's worth, most "upgrades" that Altavista, Elliot and others made were not well engineered. A toroid transformer is certainly not an upgrade compared to a good E-I transformer. What is an upgrade would be a new E-I transformer of higher quality. The core might be slightly larger, and you would have to be careful that the dimensions don't make it too large for the external box.
-Chris
Counterpoint SA 3000 TransformerHide this!Advertise here!
Power supply Schematic Counterpoint SA -3000 Help! Audiofanatic Tubes / Valves 4 6th April 2017 06:27 AM
SA 3000 Counterpoint Petergo Tubes / Valves 1 14th June 2016 05:45 PM
Counterpoint SA-3000 Kenaudion Tubes / Valves 0 19th August 2008 10:14 PM
Counterpoint Sa-3000 Circuit Diagram NickBRN Tubes / Valves 3 2nd October 2006 01:54 AM
counterpoint sa-100/sa-220 schematics? Williams Audio Analog Line Level 3 24th February 2006 05:46 PM
Copyright ©1999-2019 diyAudio
