FU50 + 6N8P + 5Z3P Amplifier
Old 23rd May 2016, 09:48 PM   #1
Vailala is offline Vailala
Default FU50 + 6N8P + 5Z3P Amplifier
p { margin-bottom: 0.25cm; line-height: 120%; }
I built my first 300B SE amplifier nearly thirty years ago. Back then SE OPTs were very difficult to find so I contacted Sowters and asked them to build me two. At first they refused, saying that SE OPTs were of antique interest only and too technically compromised for a modern hifi application. After an exchange of several letters they finally agreed to consult with their founder and technical advisor Dr G A V Sowter (then retired and in his nineties) for a design which he duly produced. From todays perspective the OPTs and the 300B tubes I sourced were very cheap, although at the time I thought them very expensive. I bought a quantity of WE300B tubes for the steep price of $15 each. These were from the UK factory and branded STC4300A.
Some years ago I thought I would build another 300B amplifier and began searching the net for the iron and tubes. Severe price sticker shock followed. There is a very strong interest in diy hifi in China and following Chinese sources for OPTs I found the FU 50 and an amplifier kit. The price of the FU50 kit with all its iron ($130) made it much, much cheaper than buying parts separately from UK and US sources. So I took a punt and ordered the kit. It came as parts and a circuit schematic. I wired it up following the classic tube amp wiring rules. Initially there was too much hum. I had used a star earth system but for convenience I had brought the two sides together using the holding screws on each side of the rectifier tube base and about an inch apart. Bringing the two sides together on the same screw solved most of the hum problem. There was some residual hum which I thought came from the transformers. Tightening the bolts made little difference but, over about 6 weeks of operation, this hum too disappeared.
I have used this amp for some years now and I am very happy with it. I rate the FU50 as better than the 300B.
So, how does the amp sound? Like all the best amps I have ever listened to, built and/or owned, it recedes into the background. It has no character in the same way that the Linley Hood 10w and the Sharp DeltaSigma amp (SM-SX100) have no defined character. One simply listens to the music the amp does not impress the listener at all. If there is any character then it is simply a slight overall grey tonality, when compared to the real thing live. All the other amps I have listened to have had a bit too much "character".
I use the FU50 amp with a Sharp DX-SX1 sacd player and a Kenwood KT990D tuner. For speakers I use a pair of probably 50 year old Australian or New Zealand made Rola 12 AlNiCo speakers in a cabinet made by AWA for broadcasting monitor purposes (AWA Studio Monitor Mk3). For the top end there are some Fostex (Foster) horns and a capacitor. This gets me close to the sound of the Altec Lansing model 19.
This FU 50 amp is still available and now can be purchased as either a diy kit or built up.
Vailala
Old 23rd May 2016, 10:44 PM   #2
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
If to use FU-50 (copy of ГУ-50) straight-forward in SE A1 mode it is a waste of a tube.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 24th May 2016, 02:02 AM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
I know little of Russian tubes because I never use them. Please educate me as to why it is a waste to use it as SE A1. Please be specific and precise. I only know that it is a power pentode.
"At the heart of quantum mechanics is a rule that sometimes governs politicians or CEOs - as long as no one is watching, anything goes." ~ Lawrence Krauss
Old 24th May 2016, 04:27 AM   #4
Anatoliy Lisovskiy
Wavebourn's Avatar
It is a power pentode designed by Telefunken for mobile amplifiers, including RF amplifiers. Filament power is low, G2 is quite dense, G3 is too (for modulation), but G1 is quite far from cathode, that's why it wants high B+, low G2 voltage, G3 is better to bias by about +15V, and use it in A2 mode.
If you find LS-50 datasheet with curves you will definitely understand what I mean.
!!!Warning!!!
Old 24th May 2016, 07:32 AM   #5
Default FU50 as triode
p { margin-bottom: 0.25cm; line-height: 120%; }a:link { } Pentode curves are irrelevant.
The advertisements for this amplifier used to make it clear that the FU50 (GU50, ГУ-50, Telefunken LS50) is being operated in triode mode. I see now that they no longer always do so.
The FU50 has a following among diy-ers in China as a triode-strapped output power valve in both SE and PP modes. It is often referred to as the little 300B because of its relatively short stature when side by side with a 300B. It is popular because when triode strapped the curves resemble that of the 300B and because it is widely available at low cost as NOS ex-military ($2 -$7 per tube). Much less than the baroque prices now commanded by new production 300Bs. An additional attraction is that the cathode is separate from the heater.
It is my understanding that the triode strapped FU50 (GU50, ГУ-50, Telefunken LS50) as SE and PP also has a following amongst Russian and German audiophiles, especially for use with LOMO Kinap, Tesla and BEAG speakers.
If you are interested in following recent Chinese diy FU50 circuit iterations you may want to look at this for a 6C16 (5842, PTT216, WE417A) + FU50 choke coupled instance.
6C16+FU50ɫصĸ߱浨ŵ·--6C16+FU50 POWER AMPLIFIER
Vailala
Old 24th May 2016, 07:55 AM   #6
Anatoliy Lisovskiy
Wavebourn's Avatar
I see, you can't read... You just repost ads... ;-)
For those who can read, here are curves for comparison. Do you see anything in common? I don't.
!!!Warning!!!
Old 24th May 2016, 09:44 AM   #7
Hahahahaha, etc, etc. I think you are fighting an imaginary battle here. My advice to you is not to learn to read (and label your diagrams) but to go back to listening to your 2.5 watt amplifier.
Vailala
Old 27th May 2016, 07:30 PM   #8
gabdx is offline gabdx  Canada
Ha!, Wavebourn 100% right
As hard a 300B is to drive, the FU50 is unusable in a tube design.
As to why fu50 is built... same thing as usual : people like the look so it sells.
I wouldn't even use that in push-pull if it was the last tube I had. I would leave tubes in their box and go transistors.
amplificateurslegrand.ca
Old 27th May 2016, 08:52 PM   #9
Anatoliy Lisovskiy
Wavebourn's Avatar
Absolutely not.
FU-50, GU-50, FL-152, SRS-552, and their original version LS-50 are excellent tubes for audio, but not in a straight A1 triode mode, and no way they are replacements to 300B. Don't compare apples with oranges, they both are great, but not interchangeable.
!!!Warning!!!
  Reply to this post
FU50 + 6N8P + 5Z3P AmplifierHide this!Advertise here!
EL34B 6N9P 5Z3P amplifier kit - any thoughts on schematic? sharpi31 Tubes / Valves 34 23rd April 2019 04:55 PM
5Z3P 6N9P EL34B SE amplifier cl1238 Tubes / Valves 6 27th February 2016 10:26 AM
HiFi 6n9p EL34 B + 5z3p Class A Tube valve amplifier mdamp Tubes / Valves 22 17th July 2014 03:42 AM
Tube(6N8P/6SN7) + MOSFET Hybrid Hifi Amplifier Kit/Board siliconray Siliconray Online Electronics Store 7 13th January 2013 01:09 PM
Great FU50 SE 12Wx2 tube amplifier kit! siliconray Siliconray Online Electronics Store 0 16th November 2011 09:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
