Mosfet or other semiconductor substitute for cathodyne?
Old 23rd July 2019, 04:03 PM   #91
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by skyra View Post
Well, then this guy is similarly ignorant because he is using the exact same idea....
No, he's not; the problem with the circuit you showed earlier isn't the topology, it's the values.
In your post #80, your circuit diagram (schematic) shows 131 volts at the FET source, and 137 volts at the drain. That means there are only 6 volts across the MOSFET; if the source rises 3 volts, the drain falls 3 volts, leaving 0 volts across the MOSFET. Even if you had a mathematically perfect MOSFET, the circuit you showed would clip as soon as the output approaches 3 volts peak (6 volts peak-to-peak.)
The problem is the 134 volts at the gate. It's far too high to allow direct-coupling the MOSFET. For a MOSFET source-o-dyne, the gate should be at about one-quarter of B+, in this case, (270/4) or about 67.5 volts. This will allow nearly 135 volts peak-to-peak from each of the two outputs, instead of the tragically small 6 volts you have now.
BTW the amp (NIVS) works perfectly with the described mod, pumping out 17 Watts of undistorted sine wave from 30Hz to 20k. How is it possible ?
When you say "the amp", I assume you mean the tube amp you showed in post # 88.
How is it possible? Because this one is designed correctly. The schematic shows the MOSFET gate at 75-90 volts. With a B+ voltage of 300 - 360 volts, this will put the MOSFET source at one-quarter of the B+ voltage, exactly where it should be for maximum headroom before clipping. The MOSFET will be able to put out about 150 volts peak-to-peak at each of its two outputs before clipping.
Again, compare this with the roughly 6 Vpp maximum output from the circuit in post #81 (which can easily be reduced to nothing at all if a different 6N2P with slightly different parameters is plugged in.)
-Gnobuddy
Mosfet or other semiconductor substitute for cathodyne?Hide this!Advertise here!
12N60C MOSFET substitute dubwoofer Power Supplies 5 2nd July 2014 10:04 PM
Substitute for BUK437 MOSFET sjdemark Solid State 3 23rd November 2011 12:27 AM
Can you use a MOSFET as a cathodyne aardvarkash10 Tubes / Valves 6 14th February 2009 11:11 PM
Substitute for mosfet darkm4n Parts 2 23rd April 2007 10:57 AM
Mosfet Substitute hifi Solid State 1 5th November 2001 07:33 PM
Copyright ©1999-2019 diyAudio
