Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#41 |
Thank you very much! Looks right.
I think mine may be made in 1989 — per the barely visible plate on the radio — but i figure, just like the car itself, it was probably produced unchanged over many years. |
#42 |
1989 impossible. That time the next car model, GAZ-24, was already discontinued. GAZ-21 was discontinued in late 60s.
Btw, there is no 1P24B in this radio. This tube was not sold to the public, the only civilian gadget using this tube that I know of was MELZ Foton UV light source. |
#43 |
That is very possible. I thought 1989 only based on this vaguely legible script.
#44 |
What I see is 1968.
#45 |
So this radio works...kind of.
The speaker output is very weak but that could be something on the radio side, not the transistor amp. I could not tune in anything on the AM scale. On FM, using a 70 to 108MHz transmitter on 71MHz, I was able to receive a very weak output. Even with the transmitter antenna touching the radio’s, reception was barely audible, but of good quality. I will check the B+ which is supposed to be 135VDC but beyond that not sure where to start. I have to say access is better than many car radios. Case parts come off all sides. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
6SJ7 Vs 6Ж8 - Can the russian tube be considered an equivalent tube ? | Kagliostro | Tubes / Valves | 16 | 16th August 2016 11:00 PM |
1p24b | milosus | Tubes / Valves | 3 | 20th October 2012 09:22 AM |
New To Site? | Need Help? |
