Has anyone used an opamp to split phase for a tube amp?
Old 6th April 2016, 09:19 PM   #31
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Also, something that works well with little tubes like an EL84, is to use LM317s instead of cathode resistors.
I had an old Fisher amp that used 7591s (similar drive and bias requirements to the EL84) that shared a common cathode resistor. I had red-plating issues since it was hard to get four really well-matched tubes.
I removed the common resistor and put four individual LM317s, wired in current-source mode, one for each tube. I bypassed the LM317s with caps so that they are voltage sources at AC (just like you would do with a cathode bias resistor). Now all four tubes automatically bias themselves each time I power up and there are no more DC imbalance issues.
My Blog: http://tubeswithatwist.blogspot.com/
Old 7th April 2016, 04:03 AM   #32
repair guy is offline repair guy
You guys were right about eliminating the 12AU7 stage, it was adding alot of noise, and just sounded odd. I rebuilt it in stereo with a TL084 quad opamp and fixed the noise and ground issues. Now I'm driving the outputs directly from the opamp and it sounds even better. Now it has some real detail and depth to the sound on headphones. I got caught up listening to CD's on it for an hour with no NFB. Still have some difficulties with adding NFB. It doesn't seem to actually change any of the ringing on the scope trace, just lowers the gain, makes the square wave sharper and extends the frequency response flat to 80,000hz, then it fades away quickly at 100,000hz.
Right now there are no capacitors in the circuit, making it a direct coupled amp. I would add them later, don't want a opamp problem to fry my tubes.
Here are some scope pics without any NFB. Didn't change the gain, just square wave input. The ringing is not from the IC, it must be from the tubes or output transformer.
1k at 1W, no NFB
5k at 1W, no NFB
10k at 1W, no NFB
20k at 1W, no NFB
50k at 1W, no NFB
Old 7th April 2016, 04:27 AM   #33
BinaryMike is offline BinaryMike  United States
BinaryMike's Avatar
The ringing is probably an output transformer resonance. It's so mild that you could be forgiven for leaving it be. The usual fix is a snubbing network attached to OPT primary, typically one series RC network across the whole winding, but sometimes more complex.
There's no apparent need for feedback to flatten response at the high end. It's considered mandatory in pentode amps to reduce output impedance, however, and we don't have evidence about low-frequency flatness or distortion yet.
Old 7th April 2016, 04:59 AM   #34
The resonance is at about 25,000hz. I know about the output impedance, but on headphones it sounds great, but on speakers it would suck. Probably when this thing is done I'll have it switch off the NFB for headphones. It still is odd to look down at the single IC doing it all, preamp and phase inversion. There's so few components there.
What values should I start with for the series RC network?
It's a 5k to 8ohm transformer.
Old 7th April 2016, 10:21 PM   #35
BinaryMike's Avatar
I usually hook up resistor and capacitor substitution boxes across the primary and just tweak for the best squarewave result. Writing in Glass Audio issue 6 of 1995, Jerry Boncer suggested making R equal to end-to-end primary Z and making capacitive reactance equal to R at the ring frequency or a bit lower. That's probably as good a starting point as any.
Old 8th April 2016, 05:23 PM   #36
JZatopa is offline JZatopa  United States
Correct me if I am wrong but those traces look like they have better phase response than I have seen in most PP amplifiers. Do you have a way to do a phase, IMD and THD graph for this circuit?
Its funny how things have changed in the past few years in tube audio. I proposed something like this a few years ago and got a mixed response. Now it looks like everyone is starting to move to the, "what ever works best is best" camp; and I am glad to see it.
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 8th April 2016, 06:51 PM   #37
Eli Duttman is online now Eli Duttman  United States
AMEN! Pragmatism should be in the forefront. I'd use a lump of galena, if it works well. Galena may be OK for an AM envelope detector, but has (IMO) no use in HIFI.
Eli D.
Old 9th April 2016, 04:11 PM   #38
stocktrader200 is offline stocktrader200  Canada
the silicon will work great as the VAS stage but almost all the tubey sound will be lost.
A tube preamp (VAS) should be use to drive the SS stage for best results.
ie. 12AX7 driving a SS 2 - 5 ma mosfet concertina driving the output stage.
Old 9th April 2016, 04:38 PM   #39
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Wait a minute.....can't we distribute "magic" Galena crystals to absorb the evil sound created by the silicon?
The early response to PowerDrive (CCS loaded triode driver, mosfet output tube grid drive) was decidedly negative about 10 years ago. I even got some email suggesting my name be changed to Transistorlab. About 400 TSE boards have been sold since then and people seem to like them (PowerDrive and DHT's).
I have some direct coupled hybrid tube / SS amps in the works, including a microprocessor controlled version.....not sure the tube world is quite ready for the Arduino / tube hybrid yet. How about the guitar amp with tubes and an Intel Core I5......That one is being built right now.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 9th April 2016, 05:04 PM   #40
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
Do I hear another "AY-men"?
I myself think that tubes are the coolest thing since individually-wrapped cheese slices, but I never did understand the whole purist mentality. The same people who bleat on incessantly about the "evils o' silicon" in a tube amp seem to have no such hangup when it comes to silicon in the signal path of their chosen source - be it a CD player, an iPad, or even a turntable.
I tend to view a well-designed hybrid as a creation that combines the best attributes of both technologies. Like Eli said, whatever works. As for the Arduino/tube hybrid: I say bring it on!
Has anyone used an opamp to split phase for a tube amp?Hide this!Advertise here!
Split supply, arrangement of gain and phase splitter tubes DrewP Tubes / Valves 4 26th July 2009 05:18 PM
Can I phase split like this? Sherman Tubes / Valves 14 16th June 2007 11:04 PM
Looking for voyd split phase circuit dhole Analogue Source 0 25th March 2005 08:17 PM
Looking for good book about phase split alan_982002 Tubes / Valves 2 29th March 2004 12:43 AM
Copyright ©1999-2019 diyAudio
