4P10C or 4Π10C tube, any member familiar with?
Old 10th September 2019, 07:44 PM   #11
adam2a3 is offline adam2a3  Greece
Hi, I just saw (after 3 years) these 4P10C tubes still sitting on a shelf here and I wonder if you tried them?
Old 10th September 2019, 08:02 PM   #12
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Since then I built some amps with them. Gorgeous!
Edelweiss-3
Edelweiss-2
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 11th September 2019, 03:54 AM   #13
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Apparently this 4P10C tube was a copy of the British VT-127D and Mazda PEN46, which have the old British "octal" base. (does not fit current octal base)
Где применялась 4П10С - ВТОРАЯ ЖИЗНЬ СТАРОГО РАДИО
https://frank.pocnet.net/sheets/146/p/PEN46.pdf
https://frank.pocnet.net/images/Maz/...6_Mazda_HM.jpg
Pen46 @ The Valve Museum
VT127 @ The Valve Museum
Old 11th September 2019, 07:04 AM   #14
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
<truncate>
Yes, the PEN46 is on the Mazda Octal (MO) base. Good pentode, but AEI's refusal to adopt the International standard octal looks like an attempted monopolistic manœuvre that went bad.
Old 11th September 2019, 09:40 AM   #15
Default 4P10C tubes
Edelweiss-3
Edelweiss-2
Excellent, so in my next amp the finals will be 4P10C. As I have to build a power amp with 6146's ppp (4pcs/ch) the 4P10C's may temporarily sit in one channel. G2's are powered through tertiary windings, Acrosound style. The Mazda octal sockets thanks to PRC are already here!
Old 11th September 2019, 02:00 PM   #16
Parafeed813 is offline Parafeed813  Netherlands
The pen46 looks very similar to the Mazda 6P28.
Only 6,3V and IO base. Equally rare it seems.
One of the many on the to-do list.
Old 11th September 2019, 04:15 PM   #17
6P28
6P28 @ The Valve Museum
Old 11th September 2019, 09:05 PM   #18
Anatoliy Lisovskiy
Wavebourn's Avatar
4P10C or 4&#928;10C tube, any member familiar with?
I made one amp using Raytheon VT127/CV1127 made for RAF. The sound and working conditions are like 4П10С, but the tube internally is different. Instead of flat cathode, grids and anode, it uses internals similar to 807, oval-shaped.
What is funny, tubes were never de-classified, so it is impossible to find printed data except test conditions. They were used in radar monitors, were quite linear for better pictures, unlike later sweep tubes that worked in pulse mode.
Matthew Willims - I contacted Anatoliy regarding an amp... | Facebook
!!!Warning!!!
Old 11th September 2019, 09:10 PM   #19
Anatoliy Lisovskiy
Wavebourn's Avatar
The only minus of Raytheon VT-127 tubes is, their Mazda bases are pretty fragile! I damaged 2 of them while pulling out of sockets, like I always do, slightly shaking around. Probably, because thin plastic is 70 years old...
!!!Warning!!!
Old 12th September 2019, 01:35 AM   #20
Maybe one could remove the old tube base with a vacuum de-solderer and replace that with a modern octal base.
2pcs 8pin Ceramic Octal Pin Plug Base For 6SN7 6L6 6CA7 EL34 Tube Test Adapter | eBay
Or use individual wire lead pin sockets, assuming they are 3 mm diameter:
Gold Plated Brass Pin Feet For Tube Socket KT88 EL34 6550 GZ34 274B Nixie VFDx10 | eBay
and/or maybe use:
4pc Octal Gold plated CMC tube Socket adapter bare PCB 2.0mm thicker | eBay
4P10C or 4&#928;10C tube, any member familiar with?Hide this!Advertise here!
Do these look familiar? rich31td Multi-Way 6 8th August 2014 07:50 PM
Brook 10c clone Briney Tubes / Valves 0 7th February 2011 05:59 PM
Manual EMT-928 longquad Analogue Source 0 3rd January 2010 11:59 AM
Genesis G-928 Servo Subwoofers Johnah13 Swap Meet 0 27th March 2009 08:02 AM
EMT 928 (& Thorens 125) snoopyma Analogue Source 1 5th January 2006 01:56 AM
Copyright ©1999-2019 diyAudio
