Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#491 |
The STF3LN80K5 MOSFET is indeed a great MOSFET for a tube driver stage. It’s a great MOSFET for a concertina too, as many people don’t know yet.
Regards, Gerrit |
#492 |
Hello Everyone,
I have decided to take the plunge into tubes and build a 01A preamp using Ale's Gyrator and Rod Coleman regs. Would appreciate advice on a few questions: 1)I plan on using one B+ supply to feed both channels with no Salas SSHV2 regs. I also plan on utilizing the B+ supply for powering the Source Follower as outlined in Ale's low gain 01A version 6 schematic. What ma draw should I plan for? If the SF is CCS biased at 10ma and the tube around 5 ma can one assume that the total draw for each channel is under 20ma, considering some losses here and there? 2)Given that I plan on building the PSU in a separate box with a 1 meter umbilical to the amp do I need to use a decoupling cap for the B+ at the entry to the gyrator or at the SF? And if so what value? 3)It looks like most recommend the Russian FT3 0.22uf for the output cap? What brand seems to work best for the gyrator cap? 4)Any suppliers of CX301A that folks are happy with? Do I look for tubes that are claimed to have been matched on the tube tester? Thanks. nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos, Millett Nutube Bal pre |
#493 |
3) Depends on the input impedance of your amplifier. Into a 47k load i settled on .47uf in my build to get the desired low frequency response. Have a play here and see what works for your application RC High-pass Filter Design Tool
I used a K72P Russian Teflon capacitor for the .47uf, and a .1uf FT-2 on the Gyrator board. 4) My advice, buy the cheapest set you can find for building and testing. They are super fragile, i have had a bunch of them die with broken filaments when shipping, and had a couple let go after repeated power on/off's while testing. When you have it all dialled, buy a nice set of matched tubes. |
#494 |
1)
Yes, using one B+ is good solution..... if you use CCS or "gyrator" as 01a anode load. These are high PSRR devices. Else you must to use complex PSU with low ripple and hum. SF and CCS or gyrator loaded VAS stage practically independent of the B+ voltage (if it as great as B+= anode voltage + swing peek + 30...40V). 2.) I use there 47uF // 100nF. 3) I use in these devices teflon FT3 // V-Cap or V-Cap or Duelund. The order of quality is the same ... but price expands to the sky. :-( |
#495 |
садовник
hi Nash, Any transistor follower (valve follower too, I suspect) needs good supply decoupling.
The decoupling should be right on the drain of the FET, for best control of oscillation risk. The idea is to prevent any part of the supply wiring from thinking about looking inductive enough to form a resonance with stray capacitance. With FETs, the oscillations can reach 10MHz or more, so a stacked-construction film capacitor is worth seeking out - these have low inductance. 100nF - 220nF. Add an electrolytic 47-100µF. |
#496 |
Thank you Mark, Bela and Rod for your suggestions.
I took a another look at Ale's 01A version 6. I missed seeing the decoupling caps C1 and C2. My apologies. Rod, I found one stacked film cap thru a Mouser search. Is this appropriate, in // with an electrolyte as suggested? F612JQ104K250C KEMET | Mouser Regarding the B+ supply, I was thinking of using this PCB with a MEC. The MEC50 is good for 50ma while the MEC100 for 100ma; which is why I inquired about the maximum current draw from the B+ supply. MEC Power SUpply Has anyone used these? Any thoughts? nash
#497 |
садовник
Yes, that's a stacked-construction part - will work very well. |
#498 |
Great! Thank you.
#499 |
Theory question: I am using Ales Gyrator boards and Coleman filament regulators with cathode bias. What is more important to match, bias voltage or plate voltage?
#500 |
Anode voltage and bias voltage determines operating point (Ua, Ia at -Vg) ... at specified tube and at given condition.
If the tube changing (another tube, or aging), the operating point also changing. There are no two identical operating point of two tubes, but if it not too far -relative to each other-, it's irrelevant. The important thing is tubes gain -preferably- similarity at near operating points. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
6V6 / 6AH4 / 01A (UX201a) | juanitox | Swap Meet | 0 | 26th May 2013 06:42 PM |
01a DHT Preamp | mogliaa | Tubes / Valves | 0 | 13th May 2012 11:07 AM |
01A tube amp Schematic??? | jmillerdoc | Tubes / Valves | 4 | 29th December 2009 02:39 PM |
Can I use a 01A in a headphone amp? | sbelyo | Headphone Systems | 27 | 28th April 2006 12:33 PM |
questions about 01A / 483 pre-amp. | RichJones | Tubes / Valves | 0 | 11th September 2003 09:46 PM |
New To Site? | Need Help? |
