01A question
01A question
Old 12th September 2019, 01:41 AM   #451
deafbykhorns is offline deafbykhorns  United States
Originally Posted by adam1016 View Post
Hello, I have been using my 01a for quite a while now, it's based off of Ale's Gen2 Design, and I am still having noise issues despite redoing my grounding, and shielding some of the signal sections. The hum really isn't too bad unless I turn my amplifier up, but the microphonics are a real killer. So much so that if I turn my amplifier up too loud, even with nothing playing, and tap a valve, it will pick up the vibration from the speaker and ring louder and louder. Also, at higher volumes, the tubes will ring on bass notes. I've bought 5 extra 01a's now and these are the least microphonic of the bunch. My chassis is a 12x12 aluminum plate mounted on wood, bottlehead style, connected with umbilicals to my power supply. I know the mounting isn't doing it any favors, but I didn't expect it to be this bad!
Put the volume control on the output
Old 12th September 2019, 07:57 AM   #452
awkwardbydesign is offline awkwardbydesign  England
I use a TVC on the output, which adds another layer of isolation.
ABD.
Old 12th September 2019, 03:13 PM   #453
That is exactly what I did, it's the best way to quiet those tubes.
I had a box of 10 tubes, all very microphonic until I added the volume at output. It works with a resistive volume control as well but the TVC works even better. I went to Dave Slagle for mine
Old 12th September 2019, 04:56 PM   #454
TVC or AVC from Slagle?
ABD.
Old 12th September 2019, 06:35 PM   #455
euro21 is offline euro21  Hungary
01A question
Without low output impedance transformer (for example next stage /SiC/FET source follower, or -at least- CCS/gyrator as active load of tube) it's a bit optimistic advice. :-(
01a has very bad behaviour to such complex load (very high inductance+not so low capacitance) as AVC/TVC. Low output impedance driver helps a lot.
Old 12th September 2019, 06:42 PM   #456
01A question
Unfortunate collusion.
I have a dozen of Sylvania 10/10Y tubes. Non of them -very- microphonic in my 10/801 preamp.
I usually use graphite anode 801 tubes, because it's musicality is outstanding.
Old 13th September 2019, 01:28 AM   #457
Using his AVC modules
They work fine driving a 6E5P on my GM70 amps
It also drives my solid state s500 threshold without a problem
No source follower required
The added plus of the autoformer at the output is that your output Z worst case will be the Rp of the tube and will quickly go down as you attenuate. At -12dB you will be around unity gain and have a Z-out of around 600 ohms.
Old 13th September 2019, 01:25 PM   #458
I considered an AVC, but bought a pair of Sowter TVCs already made up into a pre very cheaply. I wondered if the lack of isolation with an AVC might cause any problems, but have no experience of them.
ABD.
Old 13th September 2019, 02:05 PM   #459
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I own an AVC and only needs a low source impedance to works.
Old 13th September 2019, 03:54 PM   #460
Cappy is offline Cappy  United States
Ale's excellent Gen2 01A design = 18.55dB (or 8.4) gain.
Typical CD Voltage in to the preamp = 2v. That is a pretty high voltage out = 2 * 8.4 = 16.8v .
This is going to swamp the capabilities of most AVCs or TVCs, when they are put on the output of the preamp -- too much voltage in.
My system here
01A questionHide this!Advertise here!
6V6 / 6AH4 / 01A (UX201a) juanitox Swap Meet 0 26th May 2013 05:42 PM
01a DHT Preamp mogliaa Tubes / Valves 0 13th May 2012 10:07 AM
01A tube amp Schematic??? jmillerdoc Tubes / Valves 4 29th December 2009 01:39 PM
Can I use a 01A in a headphone amp? sbelyo Headphone Systems 27 28th April 2006 11:33 AM
questions about 01A / 483 pre-amp. RichJones Tubes / Valves 0 11th September 2003 08:46 PM
Copyright ©1999-2019 diyAudio
