Need an APPJ PA0901A Mini Amp Output Transformer.
Old 27th April 2015, 11:58 PM   #1
Rnaddy is offline Rnaddy  United States
Rnaddy's Avatar
Default Need an APPJ PA0901A Mini Amp Output Transformer.
Will purchase your non-working or broken broken APPJ PA0901A Mini Amp as long as it has one good output transformer.... had a clip lead to the load resistor on one channel break as I had it on the test bench. It doesn't take long to fry the little trannys.
Any suggestions on where to find a replacement would be greatly appreciated as I have done an extensive search on the net without finding a replacement.
Old 28th April 2015, 07:35 AM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
probably cheaper and quicker to stuff a couple of edcor open core units in there
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Need an APPJ PA0901A Mini Amp Output Transformer.Hide this!Advertise here!
APPJ EL84 SE mini Tube Amp, PA0901A Musik007 Twin Audio 62 6th October 2016 10:11 AM
APPJ PA0901A Repair atnaat Tubes / Valves 2 11th February 2015 01:27 AM
Something like a Miniwatt N3 or APPJ PA0901A Pdwhitt Tubes / Valves 0 9th April 2014 09:37 PM
APPJ PA0901A() schematics fx19979 Tubes / Valves 1 24th August 2013 05:27 AM
Copyright ©1999-2019 diyAudio
