Boyuu EL34 A9 Tube Amp
Thread Tools
Old 24th November 2020, 08:16 PM   #1371
gerrittube is offline gerrittube  Netherlands
How about the Takman 330k’s? I’m getting confused.
Regards, Gerrit
Old 24th November 2020, 08:57 PM   #1372
chriskim is offline chriskim  United Kingdom
think were both confused now !! so the grey unbranded ones but i suspect fake in their values was supposed to be 200k 2w - the new pink Takmans are 330k 1w - and they are almost cool to touch , Takman rate their 1w resistors to run at something like 5-600w - physically they are big as 2-3w resistors - i know some people just dont worry about cheap stuff but i always buy good quality - as in the case of me risking buying the grey200k's from ebay - look where that ended up !! normally i use hifi collective because i trust their products - Takmans are about 1.00 each - ebay pack of 10 rubbish 1.50 -- NEVER AGAIN !!
Old 27th November 2020, 09:08 PM   #1373
Right, I have used some Taskman’s too and they are very solid and have very rigid wires, perfect for my needs (including point-to-point wiring). I’ll never buy these on ebay/aliexpress.
Regards, Gerrit
Old 27th November 2020, 11:34 PM   #1374
Default Takmans
they are well worth the extra spend - all the other resistors in there are Amtrans - again superb quality and fair pricepoint ---
so my boyuu is still behaving well - very well in fact , at the technicians on Wednesday it had really good traces on the scope - sorry i cant tell you the technical stuff -- thats why i was there !! -- we found it was making about 9w running very cool and under voltages - about 2% distortion at absolute max full gain -- we helped this a little by changing the 500ohm resistance - so now rather than the pair of 1k (500ohm) we removed one on each channel - replaced with a 680r -- that has now given 404ohm resistance - i could see a big difference on the scope - really cleaned up the distortion -- no more can be got from this amp as simply the opt are rubbish !!! -- i might change them for better but now looking at building a pair of kt66-6l6gc pp monoblocks - hoping for about 30w+ -- so will probably leave the boyuu and put my money towards the new scratch build --- my boyuu is powering Klipsch R51-m spkrs -- about 92db sens -- so it does go pretty loud !! - above all its very well behaved -
Old 1st December 2020, 01:00 PM   #1375
Tubby23 is offline Tubby23  United Kingdom
Has anyone got the specs for the stock power transformer?
Or the model?
I'm particular interested in mA capacity.
What Hi-fi?!
I can only hear up to 13K!
Old 1st December 2020, 01:18 PM   #1376
I've found nothing in the way of specs for these its pretty poor that the supplier doesn't give it
Old 1st December 2020, 02:44 PM   #1377
DavidN is offline DavidN  United Kingdom
Originally Posted by Tubby23 View Post
Has anyone got the specs for the stock power transformer? ...I'm particular interested in mA capacity.
Spec is quite clear from the circuit diagram. Secondaries are:
5v @ 4A
6.3v @ 3.5A
6.3v @ 1A
315-0-315v [the choke is labelled 200mA, so that's a guide]
...and weighs 3.33Kg
Old 1st December 2020, 09:59 PM   #1378
lol
Old 4th December 2020, 07:26 AM   #1379
5v @ 4A
6.3v @ 3.5A
6.3v @ 1A
Thanks!
What Hi-fi?!
Old 20th December 2020, 11:11 PM   #1380
Brave Dons is offline Brave Dons
Hi I think one of my 6N9PJ valves has gone bad. Can anyone recommend an equivalent replacement?
Boyuu EL34 A9 Tube AmpHide this!Advertise here!
Thread Tools
Boyuu hifi Equis A10 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier: review and mod ygg-it Tubes / Valves 88 18th December 2020 01:18 AM
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 06:33 PM
FS: DIY EL34 / 6SN7 Tube Amp john65b Swap Meet 2 12th March 2012 03:02 AM
EL34 tube amp that needs work on el34ecc88 Tubes / Valves 0 17th December 2008 09:05 AM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 03:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
