Hi everybody. I have a dilemma I have to solve.
I have 8ch tube preamp with 4 dual gang potentiometer as volume adjustment.
If possible I want 1 pot to do it instead. Reason being I have to mount volume control away from preamp. preamp use 4 dual ganged 200K pots, one for each pair of channels.
What would you suggest?
I was unable to found 1 8ganged pot of that or higher value.
One thing comes to mind - get four motorized pots and have one thing control them all.
Absolutely, this is the best way, and you could use a single remote control for them.
Would you mind linking me to what are you talking about?
There are quite a few of these around, Alps makes good ones. Here's a link to an example.
MV 06 6 Way input Motorized Remote Volume Control ALPS-in Amplifier from Electronics on Aliexpress.com
That is a common use, remote activated volume controls on receivers.
Individual controls without the support stuff are sold by Mouser among others.
motorized pot Passive Components | Mouser
Thank you gents, I hoped there somewhat PNP solution to this, why is no one making 8ganged pots in 100-500K value. But thank you, I`ll have some starting point now.
Because is no market for something like that.
vicol audio : r-2r volume controller
Scroll to the bottom of page to see a custom 12 channel one.
Rgards,
Tibi
If you use motorized control pots there is no guaranty that they will all operate in sync unless the motor is of a servo type.
This will take extra circuitry to implement.
Meaning the addition of an MCU, at which there are several good solid state options available to you as well since you will need an MCU anyhow such as a pair of PGA4311's,
http://www.farnell.com/datasheets/1749095.pdf
I had just saw an 8 channel version as well but I don't remember what the part number is and who makes it, but the PGA 4311's have great specs to begin with.
Although they are limited to a 7.5v p-p swing, if you need more of a voltage swing capability then 4 pieces of either a PGA2310 or a PGA2320 would be a better solution.
They can be found here,
PGA4311 | Volume Control | Audio | Description & parametrics
jer
jer
The PGA4311 is probably your best bet. If you want to stay analog, you could use a LDR setup, but finding two sets of 8 matched LDRs could be...thrillingly expensive. I use a semi automated tester for matching LDRs and the time involved (and hence cost) is not trivial. If I work hard, I can test about 300 per day. It takes probably 1000-1500 LDRs to find 8 matched to within 1%.
Cirrus CS3318 is a digitally controlled 8 channel analog attenuator.
- Tubes / Valves
- Volume adjustment on 8ch at once
