Trying to understand 6BM8 regulator (audio note clone)
Thread Tools
Old 26th January 2014, 02:44 PM   #21
00940 is offline 00940  Belgium
00940's Avatar
Originally Posted by fdegrove View Post
The main advantage of the ECL82\6BM8 over the other ECLs is that it can take up to 900V on it's anode should you need it. That plus it's still being produced AFAIK.
Quick (and honest) question: 900V ? The svetlana datasheet for the 6bm8 gives a va rating of 600V for the pentode and the philips datasheet for the ecl82 gives a va rating of 300V.
Are those ratings extremely conservative ? Both datasheets list 2500V as acceptable for short bursts.
All that is excessive is insignificant. Talleyrand
Old 26th January 2014, 05:11 PM   #22
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Can't remember quite where I found that info but I think it's safe to say that it's wrong going by the published specs of that valve.
Sorry 'bout that,
Frank
Old 26th January 2014, 05:45 PM   #23
00940's Avatar
Sorry 'bout that,
No harm done. A bit disappointed at most
Old 27th January 2014, 03:14 PM   #24
Ketje is offline Ketje  Belgium
Ketje's Avatar
What is the problem? High voltage occures only for a short time at startup.Once stabilised the voltage must not be to high or you will disipate beyond the limit.
Mona
Old 28th January 2014, 12:32 PM   #25
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Originally Posted by SY View Post
That's a good place to end the sentence.
Try running an impulse load response.
I got a 22 volt drop with a 30ma load increase.
I find that optimizing load impulse response seems to be at odds with optimizing ripple rejection.
The ECL84/6DX8 lists the cutoff plate max voltage at 550V and operation max at 300V, so I expect 600V cutoff max is reasonable for the ECL82 along with a 300V operating max.
I've operated several brands of ECL84s up to 400V and at three times the rated plate dissipation (4W) for extended periods of time without failure.
For preamp regulators I expect the ECL84 is a good choice as well.
  Reply to this post
Trying to understand 6BM8 regulator (audio note clone)Hide this!Advertise here!
Thread Tools
What audio output xfmr for a 6BM8 pp amp? bichela Tubes / Valves 60 17th June 2016 12:29 AM
Please help me understand the voltage regulator with external bypass BJT? Fusion916 Solid State 11 15th November 2012 07:59 PM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 04:09 AM
Audio Note Clone M7 mono PCB's - 4 only! Geek Swap Meet 6 10th January 2007 10:12 AM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 06:17 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
