CR Kalypso Amp with output stage problem- Please help!
Thread Tools
Old 25th January 2014, 08:11 AM   #1
Andyroid is offline Andyroid
Default CR Kalypso Amp with output stage problem- Please help!
Hi all, I've been repairing a CR Developments Kalypso stereo 15W push-pull EL84 amp for a friend which caused an EL84 to redplate then blew its mains fuse.
So far I've replaced a leaking filter cap, crackling PI socket, now here's where I'm stuck. In doing some overall checks of continuity etc, I've found that the opposite el84 to the one which redplated has about 69k resistance between its cathode and the 180R cathode resistor. The other three el84s cathodes have about 23R going to the resistors.
This 23R appears to be from a winding on the output transformers which is directly between the cathodes and the resistors. I've never seen a setup like this.
Has anyone seen a problem like this before? would it be safe (and not too detrimental to the sound) to remove the TX winding from this spot? Should I just leave the winding 'open'?
As far as I can tell CR Developments are no longer in business and I have no idea where I would find a replacement TX.
Any help would be greatly appreciated!
Andy
Old 25th January 2014, 08:59 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The winding in the cathode is part of the signal path and provides negative feedback to the valve. This was a novel design in the 50's and 60's by Mullard. It is unusual for the winding to go O/c. Unfortunately it is a requirement of the design.
There are transformer manufacturers who will unwind and then rewind your transformer. I don't know your country but in the UK Majestic Transformers will do it for you. They are in Parkstone, Dorset.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 25th January 2014, 09:17 AM   #3
Thanks, I had a hunch it might provide negative feedback. I'll suggest the rewind option to my friend. Until then do you think simply removing the bypass capacitors would provide enough NF to keep him happy till we arrange the rewind? I'm sure the winding can't be 'crucial' to the safety of the amp. Though I don't have a schematic I'm sure I can make it work like a normal/simple push-pull amp. BTW it's not o/c, just a much bigger resistance (I suppose impedance).
Old 25th January 2014, 10:12 AM   #4
Just had a thought (first time for everything!), would this NFB winding control impedance matching with speakers?
I think this amp can be used with any speaker without actually selecting an impedance. This may be how it's done.
  Reply to this post
CR Kalypso Amp with output stage problem- Please help!Hide this!Advertise here!
Thread Tools
SM5872 - how to easily combine RO & RON and LO & LON for a valve output stage? dwjames Digital Source 4 23rd March 2013 10:11 PM
Power amp outout stage self oscillation problem ckwong99 Solid State 11 4th December 2008 02:05 PM
OP-AMP without an output stage? bigparsnip Solid State 19 14th February 2006 06:21 AM
Mismatched drivers in output stage - is this a problem? Dave S Solid State 17 29th November 2005 09:30 AM
Output stage on amp kpero Solid State 8 3rd June 2005 08:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
