Amp caused crack
Amp caused crack
Amp caused crack Please consider donating to help us continue to serve you.
Old 12th January 2014, 03:26 PM   #1
phcpbl is offline phcpbl
Default Amp caused crack
I have a Jolida integrated amplifier, JD302BRC. It has been working well until recently. Every time when I turned the amp on, during the warm-up period, I would hear a couple of loud cracks form the right channel speaker even with the volume turned all the way down. After that everything is fine, no any problem as long as it's on. It does not happen to the left channel, only the right channel.
What could be wrong? Would replacing old tubes with new one solve the problem?
Thank you for your advice.
Old 12th January 2014, 05:25 PM   #2
el156 is offline el156  Portugal
el156's Avatar
Change the tubes from right channel to the left and see what happens...if the cracks change to the left, then you have a fault tube (s).
Old 12th January 2014, 11:27 PM   #3
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
Have a go at cleaning the tube pins and if they are octal types also check the soldering in the ends of the pins. Also this can be checked by gently rocking them in the holders while the amp is on but before they get too hot to touch.
Old 12th January 2014, 11:30 PM   #4
Default Problem solved
I rotated tubes from right to left side and identified the bad tube. After replace the bad tube the speaker is dead quiet during warm up.
Thank you very much.
Old 13th January 2014, 02:30 AM   #5
H E Pennypacker is offline H E Pennypacker  Canada
Banned
I love a happy ending.
Amp caused crackHide this!Advertise here!
Unusual high-pitched whistle caused by my Audio Pre-AMP Iyzr88 Analog Line Level 9 12th August 2013 07:59 AM
Help Sony TA-1055 goes ffttzz ftz crack CRACK! Simon S Solid State 1 28th June 2013 12:42 AM
Arcam Alpha 3 Int. Amp. what caused this! dynoPort Solid State 7 7th April 2010 03:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
