Solid State Rectifier in Dynaco Tube Amp
Old 7th January 2014, 03:42 PM   #11
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by indianajo View Post
This whole discussion is *****-****. Bob Latino doesn't make or sell Dynaco amplifiers. The ST120 is a transistor amplifier. I own one. I also own a ST-70 Dynaco tube amp. Change the title of the thread or delete yourself, IMHO.
Bob Latino makes and sells Dynaco clones and uses the confusing "VTA ST-120" model name for his version of the beef-up Dynaco ST-70. This is the amp that the OP bought and are having trouble with.
Old 7th January 2014, 04:52 PM   #12
20to20 is offline 20to20  United States
There is nothing Dynaco cloned in that amp.
There is way too much Dynaco name "coopting" in the cottage industry of DIY Dynaco aftermarket.
Putting a different circuit on a similar designed steel box (he says his box is better engineered) doesn't give anyone the right to brand themselves "Dynaco." There are plenty of newbies who don't know what's, what. They just want a piece of the fun, and will buy into the fog of the hobby and keep the misnomers propogated.
20
Old 7th January 2014, 07:50 PM   #13
Matt BH is offline Matt BH  United Kingdom
If the OP's amp is indeed a Bob Latino one and it is wired the same as these:
Bob Latino Dynaco Tube amps
Scroll down for the pics.
I would strongly suggest fitting 3 wire mains lead. Also the other two howlers are pretty obvious. The mains switch and fuse!! These should both be in the live conductor preferably fuse first and if possible a double pole switch.
Shocking!!!!!!
Cheers
Matt.
Old 7th January 2014, 10:04 PM   #14
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Frank Van Alstine and Dave Curcio are two guys modding the Dynaco ST70 and have been using the Dynaco trademark, are there legal impediments to this?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th January 2014, 10:09 PM   #15
On Hiatus
SY's Avatar
Not that I can see (though IANAL)- their stuff is for actual Dynaco amps. It's like selling aftermarket mufflers or modified camshafts for Fords.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th January 2014, 10:12 PM   #16
TonyTecson's Avatar
Thanks SY, how about Bob Latino selling clones?
Old 7th January 2014, 10:53 PM   #17
On Hiatus
SY's Avatar
Dunno, never seen his ads.
Old 15th March 2019, 03:55 AM   #18
engel dela pena is offline engel dela pena  Philippines
Originally Posted by TonyTecson View Post
a lamp limiter is best to use if you plug in that rectifier, just so you have peace of mind....
another thing i do is to add two 27 ohm to 47 ohm 5 watt resistors in series with the hv windings going to the plate of the rectifiers, you lose B+ this way...
here 100R 5 watts,........kuya
Poor man's solid state replacement rectifier for Dynaco ST-70, Mark II, Mark III or Mark IV
Old 15th March 2019, 10:05 PM   #19
ejp is offline ejp  Australia
Mr. Latino's comment on the same thread, seems to indicate that the capacitors in the ST-120 should be able to handle it, no idea if the bias needs to be adjusted...
I can't see where he mentioned capacitors at all, but as his mod reduces B+ by ~0.5V there is no apparent reason why the PSU capacitors shouldn't handle it, or the bias should need adjustment either.
Again, this mod is not a rectifier replacement by SS, it just the addition of series SS diodes, apparently to protect valve rectifiers that don't meet their PIV specification. My solution would be to use a rectifier that is within spec.
Old 16th March 2019, 03:25 AM   #20
Rady is offline Rady  United States
First: using SS rectifier will increase power dissipate over output tubes; means shorter life of output tubes.
Second: installing resistors in series with SS rectifiers will sag voltage exactly as tube rectifier does. So, installing SS rectifier is not good. You can use different power transformer or use tube rectifier. Or use a variac to reduce ac input voltage.
Solid State Rectifier in Dynaco Tube AmpHide this!Advertise here!
difference between rectifier and solid state rectifier plig88 Solid State 5 15th March 2013 06:28 AM
Solid state rectifier for SE guitar amp (Vox AC4) ddr Power Supplies 6 4th June 2010 01:09 PM
Dynaco solid state manuals available for download Bob01605 Solid State 2 31st December 2009 12:52 AM
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Tube rectifier to Solid state Diodes exchange finwbu Tubes / Valves 2 20th July 2007 05:41 AM
Copyright ©1999-2019 diyAudio
