Vacuum Tube SPICE Models
Old 4th April 2014, 03:49 PM   #421
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Here's the result for the 6P36S using Multisim:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 4th April 2014, 05:03 PM   #422
artosalo is offline artosalo  Finland
artosalo's Avatar
What is the Ug2 at upper plot ?
Old 4th April 2014, 05:39 PM   #423
jackinnj's Avatar
190 -- which the EL500 shows in their datasheet. Couldn't find the datasheet for the 6P36S owing to lack of cyrillic knowledge.
Old 4th April 2014, 05:57 PM   #424
jazbo8 is offline jazbo8
jazbo8's Avatar
Many russian tube datasheets are available at klausmobile, including the 6P36S.
Old 4th April 2014, 06:43 PM   #425
artosalo's Avatar
English version: http://www.mif.pg.gda.pl/homepages/f...13/6/6P36S.pdf
Old 4th April 2014, 07:42 PM   #426
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Please help. I have Tina and I get an error "line 61: missing left parenthesis" in this 6N1P model:
Code:
* Filename:		6N1P.inc  V1  25/10/97
* Simulator:		PSpice
* Device type:		Triode
* Device model:		Svetlana 6N1P
* Author:		Duncan Munro
* Date:			25/10/97
* Copyright:		(C)1997-2000 Duncan Amplification
* Please note that this model is provided "as is" and
* no warranty is provided in respect of its suitability
* for any application.
* This model is provided for educational and non-profit use.
* Email queries to postmaster@duncanamps.com
* Pins   A  Anode
*        G  Grid
*        K  Cathode
.SUBCKT 6N1P A G K
* Anode model
* Models reduction in mu at large negative grid voltages
* Models change in Ra with negative grid voltages
* Models limit in Ia with high +Vg and low Va
* PARAMETERS
*	LIP Conduction limit exponent
*	LIF Conduction limit factor
*	RAF Anode resistance factor for neg grid voltages
*	RAP Anode resistance factor for positive grid voltages
*	MU0 Mu between grid and anode at Vg=0
*	MUR Mu reduction factor for large negative grid voltages
*	EMC Emission coefficient
*	GCF Grid current scale factor
.PARAM LIP 1
.PARAM LIF 1E-3
.PARAM RAF 9E-3
.PARAM RAP 4E-3
.PARAM MU0 38
.PARAM MUR 19E-3
.PARAM EMC 9.6E-6
.PARAM GCF 213E-6
Elim  LI 0  VALUE {PWR(LIMIT{V(A,K),0,1E6},{LIP})*{LIF}}
Erpf  RP 0  VALUE {1+LIMIT{V(G,K),0,-1E6}*{RAF}+LIMIT{V(G,K),0,1E6}*{RAP}}
Egr   GR 0  VALUE {LIMIT{V(G,K),0,1E6}+LIMIT{V(G,K)*(1+V(G,K)*{MUR}),0,-1E6}}
Eem   EM 0  VALUE {LIMIT{V(A,K)*V(RP)+V(GR)*{MU0},0,1E6}}
Eep   EP 0  VALUE {PWR(V(EM),1.5)*{EMC}}
Eel   EL 0  VALUE {LIMIT{V(EP),0,V(LI)}}
Eld   LD 0  VALUE {LIMIT{V(EP)-V(LI),0,1E6}}
Ga    A  K  VALUE {V(EL)}
* Grid current model
* Models grid current, along with rise in grid current at low Va
Egf   GF 0  VALUE {PWR(LIMIT{V(G,K),0,1E6},1.5)*{GCF}}
Gg    G  K  VALUE {(V(GF)+V(LD))}
* Capacitances
Cgk	G	K	2.4p
Cga	A	G	3.9p
Cak	A	K	0.7p
.ENDS
I can't find an error. Any help is appreciated. Thanks.
Old 4th April 2014, 08:20 PM   #427
jazbo8's Avatar
Try this one instead.
Old 4th April 2014, 08:28 PM   #428
dirkwright's Avatar
Thanks, but Tina doesn't like the "**" in it. I tried to replace all of them with EXP but it still doesn't work.
Code:
* Generic triode model: 6N1P_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sun Jan 12 18:59:00 2014
*               Plate
*               | Grid
*               | | Cathode
.SUBCKT 6N1P_AN A G K
BGG   GG   0 V=V(G,K)+-0.42063507
BM1   M1   0 V=(0.007566675*(URAMP(V(A,K))+1e-10))**-0.43818786
BM2   M2   0 V=(0.77391879*(URAMP(V(GG)+URAMP(V(A,K))/29.878541)+1e-10))**1.9381879
BP    P    0 V=0.0022884667*(URAMP(V(GG)+URAMP(V(A,K))/38.606817)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0013346379*V(M1)*V(M2)
BIG   IG   0 V=0.0011442333*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.001233721*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1.6p
CGK   G    K 3.2p
CAK   A    K 1.5p
.ENDS
Old 4th April 2014, 08:32 PM   #429
jazbo8's Avatar
Ah, the stupid SPICE syntax again... that one was for LTSpice, try the following one for TINA:
Code:
*               Plate
*               | Grid
*               | | Cathode
.PARAM X1=-0.42063507 X2=0.007566675 X3=-0.43818786
.PARAM X4=0.77391879 X5=29.878541 X6=1.9381879
.PARAM X7=0.0022884667 X8=38.606817 X9=0.0013346379
.PARAM Y1=0.0011442333 Y2=0.001233721
BK IK 0 V=U(V(G,K)+X1)*X7*URAMP(V(G,K)+X1+URAMP(V(A,K))/X8)^1.5+(1-U(V(G,K)+X1))*X9*(X2*URAMP(V(A,K)))^X3*(X4*URAMP(V(G,K)+X1+URAMP(V(A,K))/X5))^X6
BA A K I=URAMP((Y2*URAMP(V(A,K))^1.5)-URAMP((Y2*URAMP(V(A,K))^1.5)-V(IK)+Y1*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+.4)))+1E-10*V(A,K)
BG G K I=Y1*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+.4)
* CAPS
CGA G A 1.6p
CGK G K 3.2p
CAK A K 1.5p
.ENDS
Old 4th April 2014, 08:34 PM   #430
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Dirk, if you use this model in the link for TINA TI, you will need to change all instances of "**" to "^".
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 07:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 09:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 11:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 21st April 2008 12:07 AM
