Vacuum Tube SPICE Models
Thread Tools
Old 25th July 2021, 04:38 AM   #3001
Koonw is offline Koonw
"Ix(U1:Plate)" trace is not limited in your plot, try to use same Limit range in all expressions. Say if Limit(140m, ... , 0) then use same range for any other added expression.
Which bracket do you use: [] or ()? I use (). It appears to me you have a space in Limit function: Limit(1 30m, ...., 0)? You can paste the expression here if you wish.
No need to include "Ix(U1:Plate)" in all expressions of the trace plots other than the "Ix(U1:Plate)" plot itself. I can plot one myself later to confirm you try again.
Old 25th July 2021, 05:17 AM   #3002
You have plotted the same trace "Ix(U1:Plate)" twice, one with and one without Limit, remove the one without the Limit..
Old 25th July 2021, 08:39 PM   #3003
dgta is offline dgta  United States
Koonw, did you (or anyone else) try the 6AG7_GE model in post 2532 in LTSpice? I get a missing node error. Thx
Old 25th July 2021, 10:14 PM   #3004
I tried 6AG7_GE is fine. You probably have one or more unknown spice directive, maybe you mislabel a net name as spice directive?
Old 25th July 2021, 11:15 PM   #3005
This is the simple circuit. Do you see anything wrong?
Old 25th July 2021, 11:28 PM   #3006
I added this spice directives it works.
.options GminSteps=0
.options NoOpIter
.options SrcSteps=100
Old 25th July 2021, 11:43 PM   #3007
Still doesn't work for me. Here is the screen shot with the added directives.
I was running the same basic circuit with the same exact directives today with several other tubes, no problem at all. It only refused to run with 6AG7_GE.
Is the model correct for LTSpice as posted or is it for PSpice?
Old 26th July 2021, 02:35 AM   #3008
Try if any problem with the copy from me. The error message appears unrelated to the model.
Old 26th July 2021, 04:56 AM   #3009
Thanks. It was the model indeed. It took me a while to figure it out but something got corrupted when I copied the model from post #2532. I don't know what or how it happened, but I re-copied it and it works fine now. It looked the same, I didn't go through it letter by letter. I must have accidentally touched a keyboard key while cut-and-pasting it. I appreciate your help.
Old 26th July 2021, 04:34 PM   #3010
Originally Posted by EL8 View Post
intersting, the Y axis changed to mV
Oh I realise we need to be more specific about the exact unit. 11mA is more exact instead of 11m which it treated as 11mV, so it should be as below:
Limit(11mA,(263V-V1)/24.812K,0)
Vacuum Tube SPICE ModelsHide this!Advertise here!
Thread Tools
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
