Vacuum Tube SPICE Models
Old 13th November 2019, 12:24 PM   #2111
rongon is offline rongon  United States
rongon's Avatar
is there a model around for 6C45pi?
This is everything I've collected for 6C45P (6S45P). I don't have any of those tubes, so I can't tell you which (if any) of these are particularly accurate. I understand the tubes themselves have quite variable characteristics, which would make it difficult to create a one-size-fits-most model. Hopefully one of these models will work well enough for you.
Code:
* model by Eugene V. Karpov
.SUBCKT 6S45P-E  1 2 3 ; P G C (Triode) 23-Oct-2006
+ PARAMS: MU= 53.57  EX= 1.957  KG1= 126.6  KP= 368.51
+ KVB= 300.0  VCT= 0.00 RGI=1000
+ CCG=11P  CGP=5P CCP=1.9P
E1 7 0 VALUE=
+{V(1,3)/KP*LN(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G    ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG}  ; CATHODE-GRID;
C2 2 1 {CGP}  ; GRID-PLATE;
C3 1 3 {CCP}  ; CATHODE-PLATE;
D3 5 3 DX     ; FOR GRID CURRENT
R1 2 5 {RGI}  ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
From Stephie Bench:
Code:
.subckt 6C45-PE 1 2 3 ; plate grid cathode
+ params: mu=47.4501 ex=2.374193 kg1=268.615545 kp=485.735371 kvb=501.503636 rgi=300
+ ccg=2.4p cgp=4p ccp=.7p
e1 7 0 value= {v(1,3)/kp*log(1+exp(kp*(1/mu+v(2,3)/sqrt(kvb+v(1,3)*v(1,3)))))}
re1 7 0 1g
g1 1 3 value= {(pwr(v(7),ex)+pwrs(v(7),ex))/kg1}
rcp 1 3 1g
c1 2 3 {ccg}
c2 1 2 {cgp}
c3 1 3 {ccp}
r1 2 5 {rgi}
d3 5 3 dx
.model dx d(is=1n rs=1 cjo=10pf tt=1n)
.ends
Another one, but I don't remember where I found it:
Code:
* 6C45Pi PSpice model
* Joel Tunnah
.subckt 6C45Pi-j P G K
  Gp P K VALUE=
+ {(0.005984658048m)*limit(V(P,K)*ln(1.0+(0.02028899001)+exp((7.114994862)+
+ (7.114994862)*((56.68678595)+(336.3011671m)*V(G,K))*V(G,K)/sqrt((7.450118654e-006)**2+
+ (V(P,K)-(-10.58802286))**2)))/(7.114994862),0.0,1.0e16)**(1.976888442)}
  Cgp G P 4p
  Cgk G K 11p
  Cpk P K 1.9p
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6C45Pi-j
This is what I have for WE 437A (You'll need to change "^" to "**" for LTspice):
Code:
* Copyright (C) 2001 Andrei Frolov <andrei@phys.ualberta.ca>
* Distributed under the terms of GNU Public License.
* 437A  -  IDH miniature high-transconductance Bp  P K  I=(m)*uramp(()*V(G,K)+V(P,K))^1.5
* From WE 437A datasheet - traced on 24-03-02 by AF
.subckt 437A  P G K
    Cgp G P  3.8p
    Ci  G K  11.1p
    Co  P K  1.0p
* Child-Langmuir law: mean fit error 3.16544 mA
*   Bp  P K  I=(0.08803578596m)*uramp((46.53586861)*V(G,K)+V(P,K))^1.5
* Child-Langmuir law with contact potential: mean fit error 3.13346 mA
*   Bp  P K  I=(0.08984194232m)*uramp((46.41042043)*V(G,K)+V(P,K)+(-1.625595632))^1.5
* Rydel model (4 parameters): mean fit error 2.85294 mA
*   Bp  P K  I=((0.09961070341m)+(0.004497964639m)*V(G,K))*uramp((43.21809681)*V(G,K)+V(P,K)+(-8.460821328))^1.5
* Rydel model (5 parameters): mean fit error 2.5059 mA
*   Bp  P K  I=((0.1072981442m)+(0.003810318087m)*V(G,K))*uramp((46.45918184)*V(G,K)+V(P,K)+(3.803361558))^1.5 * V(P,K)/(V(P,K)+(35.10094748))
* Koren model (4 parameters): mean fit error 2.82829 mA
*   Bp  P K  I=(0.06450876758m)*uramp(V(P,K)*ln(1.0+exp((11.92107695)+(11.92107695)*(46.58588321)*V(G,K)/V(P,K)))/(11.92107695))^(1.566457341)
* Koren model (5 parameters): mean fit error 2.46529 mA
*   Bp  P K  I=(0.0391526539m)*uramp(V(P,K)*ln(1.0+exp((11.13445084)+(11.13445084)*(47.10181935)*V(G,K)/sqrt((2.879020671k)+V(P,K)^2)))/(11.13445084))^(1.667607418)
* Modified Koren model (6 parameters): mean fit error 2.05999 mA
*   Bp  P K  I=(0.04248601694m)*uramp(V(P,K)*ln(1.0+(-0.2031315389)+exp((6.39958427)+(6.39958427)*((43.26744987)+(-942.0790694m)*V(G,K))*V(G,K)/V(P,K)))/(6.39958427))^(1.648729764)
* Modified Koren model (8 parameters): mean fit error 2.03357 mA
    Bp  P K  I=(0.04441361464m)*uramp(V(P,K)*ln(1.0+(-0.08216925584)+exp((6.905076822)+(6.905076822)*((41.36290447)+(-1039.217009m)*V(G,K))*V(G,K)/sqrt((-36.83706712)^2+(V(P,K)-(10.98747878))^2)))/(6.905076822))^(1.639335869)
.ends 437A
Old 13th November 2019, 12:31 PM   #2112
disco is offline disco  Netherlands
disco's Avatar
Originally Posted by rongon View Post
This is everything I've collected for 6C45P (6S45P). I understand the tubes themselves have quite variable characteristics, which would make it difficult to create a one-size-fits-most model. Hopefully one of these models will work well enough for you.
Thanks Ron, appreciated. They take some time to settle when used for the first time, a couple of hours should do it. I'll pick the model with the nearest gm.
jaap
Old 13th November 2019, 04:33 PM   #2113
artosalo is offline artosalo  Finland
artosalo's Avatar
Something to worry about? And, is there a model around for 6C45pi?
33k cathode resistor for 6S45P is just wasting it's potential. It is best at anode current 20 mA and more.
Old 13th November 2019, 09:34 PM   #2114
disco's Avatar
Yup, just replaced it with 1K. How about the graphic, the dark figure resembles an audiofile. Some sort of oscillation?
jaap
Old 14th November 2019, 09:47 PM   #2115
dazzamps is offline dazzamps
Hi guys. I'm trying to simulate a 6L6 single ended output stage. I've been told I should be able to get 12W out of it, but using the models here I can't get past 6W.
I'm using the 6L6.inc model from Ayumi, but also tried other 6Lx6's to no avail.
Here's a screenshot of the test circuit. I simply increased the input voltage amplitude till I reached 6% THD at the output, and then measured the output power. Am I missing something obvious here, please?
ETA: Sorry, B2 should have been 240V instead, but it doesn't make a difference in the simulation
Old 15th November 2019, 06:58 AM   #2116
artosalo's Avatar
You have been told something that even the tube manufacturer does not promise.
Look at the tube data here: http://www.mif.pg.gda.pl/homepages/f...127/6/6L6G.pdf
Your main problem is far too low plate voltage (293 V).
In the datasheet 10.8 W is got with 350 V at plate (and 15 % THD), with 4k2 load impedance and fixed bias.
Old 15th November 2019, 12:01 PM   #2117
Thanks, artosalo. Much appreciated
Old 15th November 2019, 02:34 PM   #2118
One more quick question, please. Does the 6L6 have less gain than the EL84 as the simulation suggests? I can't see anything about gain in the datasheet
Old 22nd November 2019, 10:52 AM   #2119
rufus74pz is offline rufus74pz  Poland
Does anyone have tube 6AV5 plate curves curved in triode?
Old 22nd November 2019, 11:41 AM   #2120
Adrian Immler is offline Adrian Immler  Switzerland
Adrian Immler's Avatar
Hi. Does anyone have Lt Spice model for soviet 1Ж29Б rod pentode ?
Hi all,
does anybody speak Russian here?
I struggle to find the internal capacitances of the 1sh29b in its data sheet.
And translate.google just failes...
http://www.elektronikinfo.de/techpic/strom/1j29b.gif
thanks
Adrian
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 07:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 09:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 11:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 21st April 2008 12:07 AM
Copyright ©1999-2019 diyAudio
