Vacuum Tube SPICE Models
Old 12th November 2018, 12:51 AM   #1821
Koonw is offline Koonw
Originally Posted by rufus74pz View Post
Does anyone have a model for 12A4?
Code:
.subckt 12A4  P G K
    Bp  P K  I=(0.04842259598m)*uramp(V(P,K)*ln(1.0+(-0.1171696503)+exp((6.561427624)+(6.561427624)*((18.54552963)+(-100.6055605m)*V(G,K))*V(G,K)/sqrt((40.8808477)**2+(V(P,K)-(25.43292096))**2)))/(6.561427624))**(1.491616235)
.ends
https://www.google.com/url?sa=t&rct=...i8Mcq4dprcUZAH
Old 12th November 2018, 08:39 AM   #1822
rufus74pz is offline rufus74pz  Poland
Thx
Old 13th November 2018, 09:29 AM   #1823
EL8 is offline EL8
Hi, I'm looking for a model for RES964
Old 13th November 2018, 03:23 PM   #1824
Don't find sufficient data for RES964, use close substitute E443H instead.
Code:
**** E443H ******************************************
* Created on 11/13/2018 23:18 using paint_kip.jar
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file: e443h.png
* Data source link: <plate curves URL>
.SUBCKT E443H P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT E443H P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=8.001 KG1=3737.41 KP=51.11 KVB=10.8 VCT=0 EX=1.338 KG2=11692.8 KNEE=23.63 KVC=1.619
+ KLAM=1.08E-7 KLAMG=3.587E-4   KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=3P CGP=1.4P CCP=1.9P RGI=2000.0
* Vp_MAX=550 Ip_MAX=80 Vg_step=2 Vg_start=0 Vg_count=17
* X_MIN=41 Y_MIN=45 X_SIZE=976 Y_SIZE=716 FSZ_X=1550 FSZ_Y=878 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=9 Vg_qui=-16 Vp_qui=300
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n isInputSnapped=y addLocalNFB=n
* XYProjections=n harmonicPlot=y dissipPlot=n
* UL=0.43 EG2=250 gridLevel2=n addKink=y isTanhKnee=n advSigmoid=n
RE1  7 0  1G    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(G2,K)/KP*LOG(1+EXP((1/MU+(VCT+V(G,K))/SQRT(KVB+V(G2,K)*V(G2,K)))*KP))}
RE2  6 0  1G    ; DUMMY SO NODE 6 HAS 2 CONNECTIONS
E2  6 0  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))} ; Kg1 times KIT current
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*ATAN(V(P,K)/KNEE)} ; Ip with knee but no slope and no kink
RE22 22 0 1 ; E22: kink curr deviation for plate
E22  22 0 VALUE={V(21)*LIMIT(KNK-V(G,K)*KNG,0,0.3)*(-ATAN((V(P,K)-KNPL)/KNSL)+ATAN((V(P,K)-KNPR)/KNSR))}
G1   P  K  VALUE={V(21)*(1+KLAMG*V(P,K))+KLAM*V(P,K) + V(22)}
* Alexander Gurskii screen current, see audioXpress 2/2011, with slope and kink added
RE43 43 K 1G ; Dummy
E43  43 G2 VALUE={0} ; Dummy
G2   43 K  VALUE={V(6)/KG2*(KVC-ATAN(V(P,K)/KNEE))/(1+KLAMG*V(P,K))-V(22)}
RCP  P K  1G     ; FOR CONVERGENCE
C1   K G  {CCG}  ; CATHODE-GRID 1
C2   G P  {CGP}  ; GRID 1-PLATE
C3   K P  {CCP}  ; CATHODE-PLATE
R1   G 5  {RGI}  ; FOR GRID CURRENT
D3   5 K  DX     ; FOR GRID CURRENT }
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
* The following triode model is derived from pentode model, see above.
* In the triode model, all spice parameters come directly from the pentode model, except for Kg1,
* which for triode-strapped pentodes is derived from pentode's Kg1, Kg2 and Kvc as
*    4Kg1Kg2 / ((2Kvc-Pi)(2Kg1+PiKg2))
* Created on 11/13/2018 23:18 using paint_kit.jar 4.7
.SUBCKT TRIODE_E443H 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=3P  CGP=1.4P CCP=1.9P RGI=2000
+ MU=8.001 KG1=41016.82 KP=51.11 KVB=10.8 VCT=0 EX=1.338
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=y
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.ENDS
Old 13th November 2018, 08:39 PM   #1825
popilin is offline popilin  Argentina
popilin's Avatar
Hi everyone
I am looking for a model of Electro Harmonix 6922.
It is said out there that the 6N23P is the same, but the only model available is inaccurate, its iv curves are more like Siemens E88CC/6922.
Thanks in advance.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 14th November 2018, 12:12 AM   #1826
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
I made model from a set of curves that are supposedly for a 6922EH that compare to a set for for a 6N23P that I have. Who knows...
I made a comparison in LTspice in the image below.
U1 = Philips E88CC
U2 = Supposed 6922EH
U3 = 6N23P from Soviet data sheet.
Code:
* 6922EH LTSpice model
* Modified Koren model (8 parameters) mean fit error 0.20198mA
* Traced by Wayne Clay on 05/29/2016 using Curve Captor v0.9.1
* and Engauge Digitizer
.subckt 6922EH  P G K
    Bp  P K  I=
+ (0.08061132734m)*uramp(V(P,K)*ln(1.0+(-0.03708608981)+exp((3.87608812)+
+ (3.87608812)*((31.88733765)+(-1070.482271m)*V(G,K))*V(G,K)/sqrt((22.6657093)**2+
+ (V(P,K)-(4.717434742))**2)))/(3.87608812))**(1.322643185)
    Cgp G P 2.2p ; 0.7p added (1.5p)
    Cgk G K 4.2p ; 0.7p added (3.5p)
    Cpk P K 2.2p ; 0.2p added (2.0p)
    Rpk P K 1G ; to avoid floating nodes
    d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6922EH
Code:
* 6N23P LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.182649mA
* Traced by Wayne Clay on 08/22/2018 using Curve Captor v0.9.1
* and Engauge Digitizer from Soviet data sheet
.subckt 6N23P  P G K
    Bp  P K  I=
+ (0.09199263401m)*uramp(V(P,K)*ln(1.0+(-0.04545642112)+exp((4.06290859)+
+ (4.06290859)*((30.26769611)+(-1093.389027m)*V(G,K))*V(G,K)/sqrt((29.02430003)**2+
+ (V(P,K)-(11.49369847))**2)))/(4.06290859))**(1.290098711)
    Cgp G P 2.3p ; 0.7p added (1.6p)
    Cgk G K 4.3p ; 0.7p added (3.6p)
    Cpk P K 2.3p ; 0.2p added (2.1p)
    Rpk P K 1.0G ; to avoid floating nodes in mu-follower
    d3  G K dx1
.ends 6N23P
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 14th November 2018, 01:19 AM   #1827
popilin's Avatar
Hi Wayne! You are still the master!
Thanks a lot!
Old 14th November 2018, 04:04 AM   #1828
I compared the actual 6N23p with supposed 6922eh you attached, is it close, esp. towards the end. But I still think 6922eh plot is derived from the original 6N23p curve which looks so much alike but actually has much differences. Electroharmonix provides 6922eh datasheet with data only no curve plots at all (that I can find). So one must plot the 6922eh curve to see the real differences!!
Old 14th November 2018, 02:42 PM   #1829
popilin's Avatar
Both models are very close, maybe the 6922EH is based on the 6N23P or is the same valve.
The 6N23P model from post#1833 is far better than the one available on Russian forums.
Old 20th November 2018, 05:55 PM   #1830
benman94 is offline benman94
Does anyone happen to have a good model for the 6AR6/6098/6384?
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 07:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 09:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 11:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 21st April 2008 12:07 AM
