Spice model for GU50 (LT-Spice)
Thank you. In this model G3 is missing. So basically a tetrode is simulated and not a pentode. Does the model work anyway?
.SUBCKT GU50 1 2 3 4 ; P G2 G1 K (Pentode) 21-Nov-2001 X1 1 2 3 4 Tetro MU=73.53 EX=1.150 KG1=194.7 KP=13.28 KG2=4500 + KVB=30.3 VCT=0.00 RGI=2k CCG=14P CPG1=0.1P CCP=9.2P .ENDS
It works but far from accurate, here is a comparison of the model vs. the datasheet.
Who cares. GU50 pentode curves are inconsistent anyway.
What to choose?
Ex-Moderator
Joined 2011
I think Mr. Karpov built his model not based on datasheet but by tracing an actual tube, so the model would need to be adjusted to match the datasheet. I am also interested to see some actual traces of the Chinese FU50 tubes to see if they are even close to the old LS50 and GU50. Then I will build the pentode model using Ayumi's pctube.
"Hey, how did I miss those? Which make was the GU50? Just curious if those curves match up with any of the commonly available datasheets... "
They are labeled ry-50 and have two sets of three curved lines that merge to form an upside down tree with a short arrow above pointing up. Wavebourn sent them over to curve trace. Also has a diamond shape mark with OTH 34 inside, probably some test code.
