You need an anode load on the first Triode.
What are the red squares? Test Points?
Why tapped cathode resistors in the output tubes? That will just elevate teh grid and cathode by the voltage across the lower resistor.
Just tie the grid resistors to ground and use one resistor per cathode.
yes yes, thanks
should be a Blumlein Garter bias, to compensate for uneven tube wear
(but maybe its just unneeded complication, and simpler would be fine)
btw, output tubes would be...EL34, KT66, KT88, KT100...
input/driver ?
I have some 6n1p or 6n6p
or even a C3g/6C19n(6S19p) combo
OK
(looks like I can't afford to waste any voltage on the Garter bias)
thanks...yes I know
long time ago I asked about using Garter bias with SE
someone said it would work for SE as well
back then I still thought it wouldn't
beats me why I picked it up now
anyway, these days it should be fairly easy to get matched tubes from good suppliers
not perfect, never will be, but only hope its going to work ok
Put B+ into the "top" of the OPT (needs to be an SE OPT) and put the output tubes at the other end of the OPT primary and you've got a start. Not entirely sure how it works with parallel output tubes for SE. But seems like you need to read up on SE amps???
Have a look at http://www.single-ended.com/images/6550SEgood.png or http://diyaudioprojects.com/Tubes/KT88/F01-KT88-Amplifier.png for basics of wiring up SE outputs.
Put B+ into the "top" of the OPT (needs to be an SE OPT)....
despite being a nice C-core, my OPT is a PP trafo
since its a C-core it may be air-gapped
but air gap is probably too small for SE
and unfortunately also low impedance
and the reason for choosing parafeed PSE
(design with DC blocking cap)
(tempted, but not going to mess with 6c33, etc. )
(unfortunately original NOS EL/PL509 is not available any more)
(new EL509 ?...from what I have read it tend to be microphonic)
(NOS Kt100 ?...maybe, but getting expencive)
(6330 ? ... yeah, sounds like it would be nice, but also gone )
should I use a choke ?
sounds like I will need a choke
thanks
(from what I understand, CCS feed only works with triodes)
gosh, this feels like I'm loosing it now
All your schematics show DC going through the gain pot, I'm guessing you meant to put the blocking cap before that pot rather than after it?
UPS, you are right
now corrected
- Tubes / Valves
- my Dummy Amp Contraption
