Chokes in the ground "plane"
Old 17th June 2013, 02:37 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Chokes in the ground "plane"
I've often seen that in high voltage psu's the chokes can be put in the ground because that is safer. But it works just as well?
Is this the way one should do it?
If you can see the speaker cone move...it's not hifi.
http://basaudio.wordpress.com
Old 17th June 2013, 02:40 PM   #2
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Not quite. You have shown all the capacitors with a ground connection. Only the last one (C22 in your example) should have the ground connection, otherwise the ground is acting as a short circuit across the inductors. You also need to show where the centre tap of the transformer secondary goes - it should go to the negative terminal of the first capacitor (C20).
Old 17th June 2013, 02:42 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Should a choke go open circuit you could end up with high volts on the input jack ground and kill someone.
2020 versions of PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk
Old 17th June 2013, 02:48 PM   #4
I thought so. Thanks. This is actually as I had drawn it initially.
Do you mean even when it is correctly wired as below?
Old 17th June 2013, 02:54 PM   #5
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
I read about one disadvantage of this approach:
You have some stray capacitances from the transformer secondary to the core and thus to ground. This stray capacitance is in parallel with chokes in the ground return and thus bypasses them.
How relevant this effect is? I don't know. Your chokes have some winding capacitances too. So it probably depends on the transformer.
I'd get proper chokes which can handle the voltage.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 17th June 2013, 03:04 PM   #6
Ah...never knew this. I thought this approach had no drawbacks.
Old 17th June 2013, 03:14 PM   #7
DF96 is offline DF96  England
In engineering, every approach has drawbacks.
Old 17th June 2013, 03:28 PM   #8
bear is offline bear
bear's Avatar
I may be wrong, but the schematic in post 4 does not look correct to me.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 17th June 2013, 03:38 PM   #9
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
The transformer center tap must go to the first (left) inductor.
Frank
Old 17th June 2013, 04:56 PM   #10
12E1's Avatar
Not if the grounding is done correctly. You would actually end up with a high negative voltage on one side of the faulty choke, and on the negative end of those components preceding it (capacitors, other choke, as applicable). The ground would still be ground, and the HT would not be HT.
Chokes in the ground "plane"Hide this!Advertise here!
2-channel regular ground, dual mono or "balanced"/bridged? Neutrality Headphone Systems 19 31st March 2013 01:54 AM
"Ground Loop" in Snubberized PSU *fixed* Redshift187 Power Supplies 2 18th March 2012 02:34 AM
TLE-2426 as "negative" virtual ground? Steve Eddy Solid State 8 23rd June 2011 05:04 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 7th September 2008 12:35 AM
British deregulation of physics and privatisation of "s" plane EC8010 The Lounge 12 28th September 2005 09:19 AM
Copyright ©1999-2019 diyAudio
