The all DHT SET Headphone Amp
Old 14th March 2019, 10:32 PM   #871
45 is offline 45  Italy
45's Avatar
Originally Posted by popilin View Post
Does about 3mJ worth the effort?
Juan it's just for looking at things comprehensively and actually a CCS might be even cheaper than a choke if one really wants to do it.
Old 14th March 2019, 10:51 PM   #872
bondini is offline bondini  Australia
Meanwhile, I think I'm going to plug the Sennheisers in and crank it up!
Now THAT'S and idea!!
Bondini
In theory, there is no difference between theory and practice. But, in practice, there is.
Old 19th March 2019, 03:26 PM   #873
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Your schematic does not show the 32 ohm load. Do you have a dummy load hooked up to the output?
If there are no dogs in Heaven, I don't want to go there.
Old 20th March 2019, 02:59 AM   #874
Hi TheGimp,
I've tidied up the schematic to show the 32 Ohm load and the sealed lead acid battery that powers the filaments. This shows more clearly that the base of the type 30's cathode bias resistor and the top of the 6A4/LA's cathode bias resistor share the negative terminal of the battery. Similarly, the positive battery terminal is shared by filament heater pin 1 of both valves.
This arrangement was very much a matter of convenience (I was experimenting, running through several topologies, didn't want to build heater supplies, was relying on the only battery I had, a 6.3V SLA) and serendipity (hey, maybe this will introduce a bit of negative feedback via the cathodes?). As you can see from the measured output, it's below the 1V rms input for a circuit that could probably deliver open loop voltage gain of around 50, so there is probably a bit of feedback lowering the gain and the distortion.
The all DHT SET Headphone AmpHide this!Advertise here!
High end Ortho Amp on a basic Russian Tube DHT SET DIY design regal Headphone Systems 2 7th December 2012 11:46 AM
300b all-DHT SET andyjevans Tubes / Valves 16 24th August 2012 08:06 PM
Help on designing full DHT SET power amplifier milen007 Tubes / Valves 56 11th August 2011 09:38 PM
Class A, DHT driven, headphone amp iko Headphone Systems 100 26th March 2011 02:54 PM
Copyright ©1999-2019 diyAudio
