Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#21 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
This is the idea, it has been done several years in RF circuits, and rarely I saw it in audio circuits, but yesterday I made certain simulations in LTS, and is really better than I could imagine.
In my project, a 9.5 pF extends HL limit more than a decade.Note that no other value of component has been modified. In practice, it can easily implemented using 3-30pF, and adjusting them using 1KHz square wave, and watching the corners of the steeps. But I didn't know if it affects sound.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001. Argentine Ham Radio LW1DSE since 1987. |
#22 |
On Hiatus
I forgot to mention that the Marantz 9 also used the cross-coupled cap trick. So this has a long and honorable history.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is." |
#23 |
10.04!
#24 |
The circuits are too small to see, but remember that this extra capacitance has to be driven by the anode current so be careful of slew-rate limiting.
#25 | |
I don't know how to re-size the figures in this page, as I made it at full 1024*768 at my computer's screen.
#26 |
OK, a CF should help if quiescent current is high enough. One question: why not simply run with lower circuit impedances so the capacitance ceases to be a problem?
#27 |
My original idea was to made something similar to an operational amplifier of vacuum tubes. As you can see, there exist two inputs, an inverting and another NI, also at the outputs, having moderately high input impedance, gain and bandwidth, and relatively low output impedance, using only triodes, and single supply (in fact I have two, but none of them is negative). And finally, using as few capacitors in the signal path as possible.
#28 |
Interesting as an exercise in design, but why?
#29 |
For my audio project, link to the trafo thread:
Homebrew Toroidal Output Transformer The idea is to apply certain amount of FB, mixed of positive current and negative voltage to obtain a near zero output impedances as is suggested in the NFB chapter of the Langford Smith book, and others I read. But for apply positive feedback, I believe that te amplifier must be stable before using it.
#30 |
Yes, the amplifier must be super stable before applying PFB.
Thread | Thread Starter | Forum | Replies | Last Post |
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 6 | 22nd November 2018 04:36 PM |
Motional feedback amplifier based on Philips 40 wats amplifier 1970s | sanbadgujar | Solid State | 14 | 13th October 2013 02:35 PM |
converting PA amplifier into symetrical class A son of Zen amplifier | muddasirwaheedmalik | Pass Labs | 5 | 16th October 2012 05:01 PM |
An amplifier to take to University - A small low power integrated amplifier | monty78pig | Solid State | 33 | 31st August 2012 07:00 AM |
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 17th May 2005 12:58 AM |
New To Site? | Need Help? |
