Power amp with KT90s.
B+ fuse blew. Screen resistor on one tube also blew. (I use Radio Shack 1/2 watts, which act like fuses.) No further damage. No meltdown of cathode resistors.
KT90 is probably two years old, but has been in service only for a month or so. I hadn't pulled the old tubes for quite a while after I got the new ones.
Tube tests okay, shows just a little leakage from heater to cathode. No shorts far as I can tell.
I don't see anything else wrong. No sign of going off bias. Anything I should look for?
I haven't been working on the amp for quite a while. This just happened. No particular loud dynamics or anything like that.
Bad tube? Anything else I should be suspicious of?
Because I can't afford not to, I'm going with tube failure. Odd, given that the tube is so new, but it's also the only major change I've made in a while--in a rebuilt amp that has run trouble free for years. I cleaned the sockets and pins recently (and these are relatively new sockets), and I went over the solder joints when I had a problem a year or so ago.
Obviously, if this happens again, I'm going to have to rethink the "tube done it" answer.
Thanks, guys.
Thanks, guys.
