Those Magnificent Television Tubes
Old 23rd June 2019, 11:30 PM   #1131
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
If it has to be two pentodes, there is the 6GE8, but it's only 7 Watt and 1 Watt.
6BW11 gets you 4 W and 3 W pentodes.
The old standby 6LU8 and 6LR8 get you a 14 Watt P with a 2.5 W triode.
6MY8 16 W with 2.5 W triode (uprated 6LU8)
15MX8 14W with 1.5 W triode (uprated 6KY8)
832A 15W P + 15W P
Old 23rd June 2019, 11:37 PM   #1132
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Many thanks all. I'll have a look at those and compare to something like a 6T10.
Don't try to be a great man ... just be a man. Let history make its own judgments. Zefram Cochrane
Old 24th June 2019, 07:29 AM   #1133
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Originally Posted by mashaffer View Post
Anatoliy, I am having trouble envisioning what you are describing.
George already explained. Damper diodes prevent high voltage spikes on the primary when the amp is clipping without load. A foolproof.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 24th June 2019, 09:47 AM   #1134
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i have seen hgh power guitar amps with tether diodes .....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th June 2019, 11:48 AM   #1135
kissabout2002 is offline kissabout2002  Italy
Hi Wavebourn, does exist on Russian tubes dissimilar dual triode like 6CY7 or 6EW7 ? ...all the best
Old 1st July 2019, 12:58 AM   #1136
Anatoliy Lisovskiy
Wavebourn's Avatar
I can't say that I know all Soviet tubes, but with 99.9% probability, no.
Triodes - pentodes, yes. 6F1P, 6F3P, 6F4P, 6F5P, analogs of Western tubes. And one magnificent Soviet tube of late color TV era, frame grid triode-pentode 6F12P.
!!!Warning!!!
Old 2nd July 2019, 02:42 AM   #1137
thank you
Old 14th July 2019, 07:22 PM   #1138
MarcelvdG is offline MarcelvdG  Netherlands
For those who understand Dutch:
Nederlandse Vereniging voor de Historie van de Radio
Lecture by Bernard Terlingen, now 80 years old, on how he used to collect television valves from waste bins, built high-power audio amplifiers with them and used those to play the Hallelujah from Handel's Messiah at the start of the new year at a high enough volume to overcome the sound of the fireworks. The turntable had to be placed at the other side of the house to prevent oscillations due to acoustic feedback.
Those Magnificent Television TubesHide this!Advertise here!
MOAK: The Mother of All Karlsonators (aka The Magnificent Monster) DeonC Subwoofers 126 23rd January 2015 04:35 PM
Television question... toptip Everything Else 6 23rd October 2012 07:50 PM
Surround sound amp, Sub woofer and television warrennyc Subwoofers 4 3rd January 2005 11:33 AM
distance from television ALFIrE Multi-Way 2 30th March 2004 07:46 AM
Television broken Bull Everything Else 3 21st January 2003 01:08 AM
Copyright ©1999-2019 diyAudio
