That's probably not a good transformer- with a full wave rectifier, the voltage will be too low, with a doubler, it will be too high. See if you can find one with a 300-320V or so secondary to get you 500-450V raw supply.
I have two 240VAC = 480VAC, it's ok? what's your advice do it with Salas HV2 reg or using the schematic for B+?
My advice is to use a different transformer. 480V AC will give you almost 700VDC, which is a lot of volts to drop. An Antek toroid will cost you something like 25 euros.
- Tubes / Valves
- ImPasse Preamp now online
