Importance of Screen Voltage of Pentode???
Old 18th September 2020, 07:18 PM   #61
Paul Joppa is offline Paul Joppa  United States
Screen voltage sets the maximum current at zero G1 voltage. Many data sheets show plate curves at G1 = 0, at several G2 voltages. If G2 voltage is higher than needed, the screen draws (wastes) more current, risks overheating G2, and enables more spectacular self-immolation and arcing.
There are two main reasons for running plate voltages at or near screen voltages:
1) to save the cost of a G2 supply - a resistor and cap, or a regulator, or a separate supply, whatever.
2) Ultralinear operation with a simple output transformer (no tertiary winding).
Both are economic, not performance issues.
  Reply to this post
Importance of Screen Voltage of Pentode???Hide this!Advertise here!
Importance of resistor working voltage spec? leadbelly Parts 15 20th July 2014 03:13 AM
Pentode cathode follower with regulated screen voltage? G Tubes / Valves 14 18th November 2013 11:01 PM
Output Pentode Screen at half Plate voltage Andrewbee Tubes / Valves 32 2nd May 2012 11:41 PM
Do EL34s in pentode mode PP AB1 sound better with lower screen voltage? ray_moth Tubes / Valves 11 1st December 2010 02:59 PM
Setting Pentode Screen Grid Voltage dshortt9 Tubes / Valves 1 19th January 2003 11:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
