questions about 01A / 483 pre-amp.
Thread Tools
Old 11th September 2003, 09:46 PM   #1
RichJones is offline RichJones  United States
Default questions about 01A / 483 pre-amp.
I'm gonna build a pre-amp with the 01A or 483 with a MOSFET source follower as the output.... see any of the Alan Kimmel pages.....
run the tubes at the standard op point...unless there are "better" ones? and the SF at 50 mA.
Question is:
I want to use MV rectifers and VR tubes... maybe the 150v ones... recommendations?
should I limit the LC sections, choke input PS or what??????
Remember that I should get a VERY high PSRR for this circuit.
Finally, in the Alan Kimmel circuit, attached, can I replace Rp for a choke????
Thanks!!!
  Reply to this post
questions about 01A / 483 pre-amp.Hide this!Advertise here!
Thread Tools
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 10:26 AM
PSU for QSC amp questions rkc7 Parts 5 10th November 2005 06:18 PM
Last questions about this Madmike2 Multi-Way 9 14th June 2005 12:12 AM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 03:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
