new chinese tube manufacturer
Old 15th October 2011, 09:42 PM   #1
v4lve lover is offline v4lve lover  Netherlands
Location: Surrounded by glass, no really my room is full of tubes
Default new chinese tube manufacturer
after just stumbling across some strange names on ebay , there seems like a whole new vacuum tube producer has set up shop in mainland china
their name is Guiguang they claim to be the phoenix that has risen from the remnants of the original Liuzhou Electron Tube Factory
this is the mainpage Foshan Nanhai Guiguang Electron Tube Factory
seems pretty damm legit nixe new factory whit CLEAN equiptment as opposed to shunguang . the old factory was claimed to be superior to any other chinese factory's as ive read .
their products seem to be tidy and well thought out . take for example their 2a3 has double mica .
im thinking this will bring some new intresting products .
surely somone must be constructing something whit the load of new DHT triodes pouring out of china
edit their not even skipping the most important thing ! their outgassing their materials . just like svetlana did and does ultimate lifetime
Old 15th October 2011, 10:26 PM   #2
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Been around for at Least a year and a half....
Got some Guiguang 300B a year and a half ago!
Das Beste Oder Nichts
Old 16th October 2011, 07:02 AM   #3
Defiant is offline Defiant  United States
Defiant's Avatar
Their KT-88 looks nicely built. Who is their US distributor?
Old 16th October 2011, 11:55 AM   #4
rss388 is offline rss388  United States
Any feedback on those 300Bs?
Old 16th October 2011, 11:57 AM   #5
Hmm, I am going to be in the next town over from Foshan. I wonder if I could pop over there and check them out and at the same time go see Yaqin as well (Yaqin is also in Foshan).
Old 16th October 2011, 02:15 PM   #6
PreSapian is offline PreSapian
by out gassing do you mean burning off whatever the toxic material that's present? i never thought tubes as having such issues since it's main structure is a sealed glass.
could you specify, please?
Old 16th October 2011, 04:45 PM   #7
Alastair E's Avatar
Outgassing--
The process whereby the internal metal parts of a vac. tube are heated to above any concievable normal working temperature, (Normally a glowing red-orange heat) to remove any occluded air and gasses from the metal itself...
Prevents a tube's vacuum from going 'soft' after some time of use and allows the getter to mop up any traces not removed by the outgassing process without becoming 'spent' too soon...
With regards the 4 300B I have from GuiGuang, they were bought for a project that I still have yet to finish.
I have tested them on my Taylor 45C Mu tester, they test fine, and are closely matched....
Old 16th October 2011, 04:59 PM   #8
^good to know. thanks
i too have guiguang 300b ready for my tubelab se project. they were about the cheapest thing i could find on this side of the planet, but has an excellent build quality with a ceramic base ect.
Old 16th October 2011, 06:52 PM   #9
Alastair E's Avatar
Ah--yes, They seem well-made, and I expect they will perform well...
Emission is very good, as indicated by very little reduction in Gm when running at a low heater-volts on the tester....
Ive no idea (yet) what they sound like, but for the price well.....
Old 16th October 2011, 06:58 PM   #10
yeah judging the factory pictures its a major advance . no cut corners it seems .. now if they only made some REAL 211 845 and maybye a new manufacturer of 6080 ? they are already making el34 it seems
new chinese tube manufacturerHide this!Advertise here!
Chinese Tube Amps? samsagaz Tubes / Valves 9 30th April 2008 06:52 AM
chinese tube amp squirtacious Tubes / Valves 36 10th November 2007 04:06 AM
Tube manufacturer Trivia Question planet10 Tubes / Valves 24 10th October 2004 11:31 PM
Copyright ©1999-2019 diyAudio
