I was trolling the local classified posts and I found someone selling an Eico HF-86 for $250 in "very good condition". I haven't requested pictures yet, if it is fully functional, or if it has tubes or not. I am wondering if this is a reasonable price for this amplifier? I'm not real up on vintage gear and what they are bringing these days. Thanks!
Check the schematic out. The "iron" should be decent, which gives you all sorts of options. The 'U7 section of the 12DW7 definitely makes a better "concertina" phase splitter than a 'X7 section does.
If the seller will come down a bit, buy.
The HF-86 is stereo, and is basically the same power amplifier section as that of the HF-81, so it certainly has its following (they use the same transformer set).
While the Eico transformers are decent enough, in my experience they are no match for the ST-35's transformers. The Eico transformers typically have a power bandwidth of 10 watts RMS from 30 Hz to 15 kHz, where distortion can be typically held to typically no more than 1% THD in the usual designs.
On the other hand, the ST35's transformers can handle more power, at less distortion, and across the full 20 - 20 kHz bandwidth.
With some haggling, the Eico isn't bad, but the Dyna would be the better performer.
Dave
Dave
Thanks a lot guys!
I'll be calling the seller tomorrow, getting some details on this amplifier, and I'll see if I can bring him down in price. It might be a big week, my girlfriend found me a lead on some Western Electric gear. We'll see how that goes. Thanks again, I'll be posting back with pictures if I end up with the Eico!
