Best method of reducing line voltage into vintage transformers?
Thread Tools
Old 28th June 2011, 09:09 AM   #11
trobbins is offline trobbins  Australia
trobbins's Avatar
Transformer insulation between primary and secondary, and secondary and secondary can be very different, and certainly requires different standards compliance. One meets basic/reinforced requirements, the other can be functional only.
The magnetising current increases with voltage. A normal transformer would have to cope with +10% rated mains voltage. If the original was rated 115, then you are asking it to nominally cope with 125+10%. If it was prone to getting hot at 115 (for example), then the balance may well be tipped at 138V.
Old 28th June 2011, 10:42 AM   #12
costis_n is offline costis_n  Greece
Yes you should always observe the VA ratings of each winding and the total VA rating.
  Reply to this post
Best method of reducing line voltage into vintage transformers?Hide this!Advertise here!
Thread Tools
Reducing transformer voltage... 69CamaroSS396 Power Supplies 7 27th May 2009 08:25 PM
reducing voltage rtill Solid State 28 16th January 2009 01:45 PM
Reducing PSU Voltage hernanstafe Parts 1 9th March 2007 05:14 PM
Best way of reducing heater voltage? showdown Tubes / Valves 14 20th July 2006 07:15 PM
Reducing Voltage in a safe way. darkm4n Solid State 106 7th March 2004 12:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
