4P1L DHT Line Stage
4P1L DHT Line Stage
Old 17th April 2019, 01:57 AM   #1631
mr ed is offline mr ed  United States
I just move to Willis in 2014.
Austin area since 1982. I like San Marcos, have other family in thearea.
Cheers
currently watching electrons party under glass
Old 19th April 2019, 08:26 AM   #1632
andyjevans is offline andyjevans  United Kingdom
Thanks to the suggestions here I left out the resistor at the top of the SIC diodes - turned out it wasn't doing anything useful and the sound was better with just the diodes. I A-B'd the 4P1L with my large NP Acoustics plate choke against the 26, and I'm slightly preferring the 26. It has more "life" and makes the 4P1L, which is otherwise very detailed and neutral, sound just a touch two-dimensional. I've been running the 26 at 7mA without any obvious ill effects.
Old 19th April 2019, 01:33 PM   #1633
vcoustics is offline vcoustics  United States
I have a 4P1L using the K & K audio board (great build quality) and Rod Coleman Regs for each tube.
Issue I am having: the f- and f+ is always rising to 2.7 V which it too high and not the 2.1 the data sheet dictates. Anyone incountered this? I dropped the supply voltage down to 13.5V in a attempt to lover the f voltage and still 2.7.
Should the tubes also be making a chime noise during warmup?
Might be the way too high f voltage. I only ran them a few min because of the high voltage.
Old 19th April 2019, 07:19 PM   #1634
I'm sure Rod will come in here, but 13.5v seems far too high as a supply voltage. I think it depends which vintage of Coleman regs you have. Around V4 you needed approx 7v headroom which puts the supply voltage at around 9v. We're now on V7 and I think the ideal headroom is a bit below that. So I'd try 9v supply just to start with, not more. You also need to use the onboard trimmer to set the voltage correctly once the supply voltage is in the right range, with your voltmeter between pin 7 and pin 1+8. I assume that's how it's connected for 2.1v. If you have a bench voltage supply you can bring the voltage up gradually and you should come to an area (probably around 7-9v supply) where the filament voltage stabilises and goes up more slowly. This is the area where the reg should be working correctly. The voltage continues to rise, but more slowly.
Have you fully read Rod's instructions for use of the reg? His instructions are a model of completeness and clarity.
Old 19th April 2019, 09:13 PM   #1635
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
4P1L DHT Line Stage
Yes, 13.5V supply is very high - unless you have a filament bias resistor.
Is the filament connected in parallel mode for 2.1V?
If you send me some email, I can send the debug test points - if there is anything wrong, it will show up there.
When a DHT filament warms up, it slackens its tension, and this can chime on the supports.
Old 19th April 2019, 11:12 PM   #1636
Silly mistake - connection in parallel is between pin 8 and pin 7+1. Sorry!
Old 20th April 2019, 11:45 AM   #1637
I do use a Fill bias resistor at 12R.
I Use the V7 version.
I use the 8,1 and 7 to get the 2.7V
Even as I adjust the trim pot on the Regs it still floats at 2.7. Could the pots screw mechanics be broken? Or melted? I have large heat sinks on them and they get luke warm at best.
Old 20th April 2019, 07:24 PM   #1638
работник
4P1L DHT Line Stage
Please send me some email - I can send a guide to taking a handful of voltage measurements, that will show what is wrong.
Old 22nd April 2019, 11:57 AM   #1639
Frank40 is offline Frank40  Denmark
Frank40's Avatar
I can see that some of you uses diodes as bias for your tubes, it seems to me that the reason must be to get a low value of cathode impedance in the absent of an cap.
But you lose the ability to adjust to a precise current. I was thinking of another solution, se schematics below. Please tell me if you think it will work.
The dynamic resistant is roughly R (in ohm) = 25/I cathode (in mA)
Old 23rd April 2019, 12:54 PM   #1640
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
4P1L DHT Line Stage
The use of SiC diodes or some specific wirewound resistors has to do solely on their sound clarity. There are multiple ways to bias a stage (like there are to skin cats as they say) but not all sound equal
You can build and compare the one you show above.
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
4P1L DHT Line StageHide this!Advertise here!
All DHT Phono Stage Steve Cresswell Tubes / Valves 32 2nd April 2013 06:24 PM
one stage DHT amp Jaime Tubes / Valves 2 18th October 2010 12:31 PM
Which DHT for Line stage? andyjevans Tubes / Valves 15 26th March 2009 01:10 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Copyright ©1999-2019 diyAudio
