Unexpectedly good EL84 amp
Unexpectedly good EL84 amp Please consider donating to help us continue to serve you.
Old 10th September 2018, 07:51 AM   #51
andyjevans is offline andyjevans  United Kingdom
Originally Posted by Fenris View Post
The gain of the 6N1P is about 35. Putting a LED in place of the cathode resistor should ensure that you get all of that gain.
I question whether you need 3 stages, since the EL84 is a relatively high mu tube. My Leak Stereo 20 uses 6S4 triodes instead, in PPP. They have a mu of 16.5. I reworked the chassis slightly. Currently it has an ECC40 front end as a diff pair. Mu 32 and sounds nice, but different socket. I'll find an alternative, and currently thinking of a directly heated 3a5 for that.
As regards bias I've been getting very interesting results with SIC diodes, specifically C3D02060F. Something I got off Ale Moglia's 01A preamp in a recent shootout. This is my bias of choice right now. Each diode is giving me .92v in my 26 preamp. In that preamp I add a 120R resistor to the chain for a little feedback. Sound is very clear and clean.
Old 10th September 2018, 02:42 PM   #52
mark02131 is offline mark02131  United States
mark02131's Avatar
I'm thinking by lowering the 30K resistors to 15K I can get the current up enough to drive the 6L6 grids without the need of additional driver pair. If it were EL34 then for sure but with 6L6's I may be able to drive them without the need for that extra pair.
Old 10th September 2018, 04:12 PM   #53
Fenris is offline Fenris  United States
Andy, Mark was talking about driving 6L6 tubes rather than EL84. That's about twice the voltage drive and probably more current if going into AB. And once you go into AB, those 6L6 grids can draw some current. The one weakness of the concertina using a tube is that due to the Rp, the output signals have uneven current capabilities. A MOSFET has a far lower Rds which gives more balanced current capabilities.
I've run this circuit with a 6N1P, EL84s and a MOSFET in place of the second tube, but without the bypass cap in order to lower the gain. It works brilliantly. You could do two stages instead of 3, but it's the same number of tubes and the first diff pair would need a CCS to get good results - which may require another power rail.
One of the subtle brilliances of the original circuit is that the resistors in the first two stages are matched. Any current increase in the first stage is matched by a current decrease in the second stage, and vice-versa. The same goes for the balanced output stage. This results in a constant current circuit, which keeps the power supply from being modulated by changing currents.
Listen to the music through the stereo, not the stereo through the music.
Old 10th September 2018, 04:46 PM   #54
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
This circuit and variations thereof are probably my most commonly built schematic. I'v done many builds based on the same basic idea, just with values changed to suit.
Other than my flea amp (a real giant killer!!!!) my current daily use amplifier is this circuit, with 6N2P input/phase inverter, 6CW5/EL86 outputs, with garter bias cathodes. All toroidal power and ouput iron. It's powerful, affordable, easy to drive, and sounds fantastic. LED biased 6N1P up front would be a great way to go if you don't want/need the extra gain for feedback, or if you have hot sources feeding it.
6SN7 Push-pull Flea Amplifier PCB files are now available!
Old 15th October 2018, 10:34 AM   #55
vuohi is offline vuohi  Finland
I'm building this amp and I've got one channel assembled so I was doing my initial testing and measurements on it. My voltages are pretty close, but I'd like to tweak them a bit to get closer to the values in the schematic. Both halves of the 6N1P have a 30k resistor at the anode, but I'd get closer to nominal voltages by replacing one of those resistors with a slightly lower value resistor. My question is would this do more harm than good? I'm only about 10V off and I was wondering if there's a particular reason why the anode resistors are the same value.
Old 15th October 2018, 12:18 PM   #56
Lingwendil's Avatar
10 volts is nothing in the grand scheme of things with tubes in general. I wouldn't bother changing anything. Built as shown, it's a very good circuit.
Old 15th October 2018, 06:36 PM   #57
Francois G is online now Francois G  United States
Originally Posted by Lingwendil View Post
.... my current daily use amplifier is this circuit, with 6N2P input/phase inverter, 6CW5/EL86 outputs, with garter bias cathodes. All toroidal power and ouput iron. It's powerful, affordable, easy to drive, and sounds fantastic....
I don’t want to highjack the thread, but I’m really interested in more details of your EL86 amp. Do you have a link, or please send me a PM. Thanks
Old 15th October 2018, 06:49 PM   #58
Lingwendil's Avatar
Sure thing, it's got it's own thread right here-
6N2P/6CW5 design with toroidal outputs
Old 15th October 2018, 07:15 PM   #59
I donít want to highkack the thread, but I really interested in more details of your EL86 amp. Do ypu have a link, or please send me a PM. Thanks
Old 17th October 2018, 06:32 AM   #60
Yeah, I don't think I'll bother. All the voltages are close enough.
But still the question remains, is there a reason why the anode resistors are both 30k? I have a faint recollection of someone mentioning something about this, but I can't remember where I saw it. I don't understand what difference it would make even if they were different values as long as the voltages are right.
Unexpectedly good EL84 ampHide this!Advertise here!
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 09:46 AM
what's a good layout for a quad EL84 amp on this box? freddi Tubes / Valves 3 18th July 2010 04:03 AM
1 pr. GE 6BQ5/EL84, barely good, $5 pjanda1 Swap Meet 2 23rd September 2008 10:32 PM
Speaker unexpectedly popping OUberLord Car Audio 10 1st September 2004 01:10 AM
triode => I.T. =>el84 good idea ? Jaap Tubes / Valves 9 7th January 2003 08:30 PM
Copyright ©1999-2019 diyAudio
