Unexpectedly good EL84 amp
Old 26th March 2011, 06:55 PM   #11
andyjevans is offline andyjevans  United Kingdom
No global feedback I see. I did much prefer my EL84 amp without.
I originally tried UL with no global feedback. It was better than with feedback but I felt that there was a hint of sharpness so didn't pursue it
Andy.
Old 26th March 2011, 07:21 PM   #12
Poindexter is offline Poindexter  United States
Originally Posted by Eli Duttman View Post
I would think power O/P is less than 8 WPC. Look at page 3 of the GE 6BQ5 data sheet, where some PP AB1 triode mode conditions are given..
Whut Eli sez. You are going to get four watts, maybe five max, from this circuit. If you load down the outputs with a lo-Z output transformer in the attempt to get a little more power, you'll get that late tube soft sound.
That said, you'd be surprised what five watts can do, as long as you're not trying to drive Acoustats with 'em.
Aloha,
Poinz
Old 26th March 2011, 07:58 PM   #13
Shoog is offline Shoog
Shoog's Avatar
I really would be inclined to try an experiment of disconnecting the bypass cap on the outputs and seeing how it sounds. It shouldn't make much difference to the output power.
Shoog
Old 26th March 2011, 08:35 PM   #14
cjkpkg is offline cjkpkg  United States
I have built this one too!
I made a couple tweaks so far...I implemented a CCS for the EL84 cathodes using an LM317 to hit 80mA total per channel.
I also implemented some red LEDs for the front cathodes of the 6n1p's in lieu of the resitors.
This amp really rocks! and is very tweakable...
Old 26th March 2011, 08:42 PM   #15
woodturner-fran is offline woodturner-fran  Ireland
Shoog - you mean the 1000uf on the cathodes of the 84s?
Cjkpkg : would you post some schematics?
Fran
Old 26th March 2011, 08:47 PM   #16
Shoog's Avatar
Yes that one. It would become semi-differential. If it worked then replace the 400R with a LM317 CCS.
Shoog
Old 26th March 2011, 08:55 PM   #17
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Nice amp. Very optimal, and should sound nice.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 26th March 2011, 08:58 PM   #18
6L6 is offline 6L6  United States
6L6's Avatar
Hmmm..... I think I should use my old Fisher guts/chassis and make this amp...
Old 26th March 2011, 09:33 PM   #19
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
I've built this amp up, but with 6CG7 drivers and Sy's led output stage biasing scheme. Very nice amp, and plenty of volume from every speaker I've tred, even low efficiency types. Very nice sound, tryed a led on the 6cg7's cathode, and it seems like slightly more usable volume before breakup. All in all, a great amplifier.
Old 26th March 2011, 10:02 PM   #20
This is how she turned out:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Unexpectedly good EL84 ampHide this!Advertise here!
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 09:46 AM
what's a good layout for a quad EL84 amp on this box? freddi Tubes / Valves 3 18th July 2010 04:03 AM
1 pr. GE 6BQ5/EL84, barely good, $5 pjanda1 Swap Meet 2 23rd September 2008 10:32 PM
Speaker unexpectedly popping OUberLord Car Audio 10 1st September 2004 01:10 AM
triode => I.T. =>el84 good idea ? Jaap Tubes / Valves 9 7th January 2003 08:30 PM
Copyright ©1999-2019 diyAudio
