Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#161 |
Very nice build
#162 |
... fascinated by amps
Hi Peter,
your amp looks great ! Glad that you enjoy it so much as well ![]() Where did you get the trafo covers ? They look very professional. With regard to the heatsinks for your current sources, you may fix them to the PCB with hot melt glue (provided that they don't get extremely hot in use ... ![]() Also, I would recommend securing the Mundorf caps with hot melt glue to the PCB. That not only helps for a safer long-time connection, but also can damp vibrations that originate from the power transformer ... Best regards, Claas |
#163 |
Hi Claas,
Thanks! Good idea with glueing the capacitors. I'll check if if works for the heatsinks as well. The transformer covers came from Aliexpress: PAPRI 1PCS 85*85*100mm DIY Black Metal Transformer Cover Case Box HIFI Protect Cover Enclosure For Audio Tube Amplifier-in Amplifier from Consumer Electronics on AliExpress - 11.11_Double 11_Singles' Day There are different sizes... |
Thread | Thread Starter | Forum | Replies | Last Post |
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk | radiostar | Swap Meet | 3 | 29th January 2012 09:46 AM |
what's a good layout for a quad EL84 amp on this box? | freddi | Tubes / Valves | 3 | 18th July 2010 04:03 AM |
1 pr. GE 6BQ5/EL84, barely good, $5 | pjanda1 | Swap Meet | 2 | 23rd September 2008 10:32 PM |
Speaker unexpectedly popping | OUberLord | Car Audio | 10 | 1st September 2004 01:10 AM |
triode => I.T. =>el84 good idea ? | Jaap | Tubes / Valves | 9 | 7th January 2003 08:30 PM |
New To Site? | Need Help? |
